Seasoning a used cam.....
2eighTZ4me
I have a Racer Brown cam (springs, retainers, etc.) that came off a running car. Lobes look ok. I have a set of factory rockers that were reconditioned by Delta Cams. Most of what I have read about seasoning a cam has to do with a new cam or a regrind - not one that's been run in another head.
What steps should I follow to make sure this guy gets broken in properly? I am going to use Valvoline VR1 oil with ZDDP for the initial run for sure.
Do I need to run it at 2K RPM's for 30 min. as one normally does for a new cam?
That one has been an area of contention for a long time. Some people say you need new rockers. Some say you can resurface the rockers. Some say you can run the old rockers. It's a long standing debate. My take is that you can use the old rockers. My rockers are on their 3rd camshaft, no problems.
