grumpyvette Posted May 19, 2010 Author Share Posted May 19, 2010 a bit more info about the current condition of your car and drive train would be most useful, pictures of your car would help ID suggest buying these books as a start point http://www.themotorbookstore.com/resmchstvi.html http://www.amazon.com/Rebuild-Small-Block-Chevy-Engines-Hp1393/dp/1557883939/ref=sr_1_1?ie=UTF8&s=books&qid=1274295954&sr=1-1 http://www.amazon.com/John-Lingenfelter-Modifying-Chevy-Engines/dp/155788238X/ref=sr_1_3?ie=UTF8&s=books&qid=1274296049&sr=1-3 Quote Link to comment Share on other sites More sharing options...
Wilson_WWSC Posted July 4, 2013 Share Posted July 4, 2013 (edited) What is the proper way to set up a PCV system? I will probably go with the common route of a breather on one valve cover and a pcv valve on the other (connected to the carb or intake), but how do I select the proper PCV valve? I've tried to research it and have found no definitive answers to which valve works. I will be rebuilding my chevy 327 with RHS pro action 180cc/64cc heads, a Howards Cam roller 270/278 cam, Edeldbrock performer rpm intake, Holley 600cfm vac secondary carb. I haven't decided what to do with the bottom end yet. I may go 030 over if my pistons are dished (I want flat top) or if the pistons are not in good shape. Also, any suggestions for the bottom end? Leave it stock if everything looks ok? This is going in my 240z. Thanks! Edited July 4, 2013 by Wilson_WWSC Quote Link to comment Share on other sites More sharing options...
MONGO510 Posted August 7, 2013 Share Posted August 7, 2013 Hey Grumpy, been a while since I've been here. My question is this...... I just scored a 400, 4 bolt main, 511 block . It is standard bore and may very well clean up with a good hone job. It was purchased from Somers racing engines and he said it was the straightest factory block he has seen. If this is built properly, what kind of boost levels do you think it could withstand running a banks Twin turbo kit. Problems with ring seal due to thin casting? power levels?Head gaskets? Thanks, Mongo510 Quote Link to comment Share on other sites More sharing options...
daflyinghawaiin Posted August 8, 2013 Share Posted August 8, 2013 Hello grumpy! some great info in this thread you are very knowledgable indeed. My plans for my 83 280zx is to do a sbc swap and that way i can actually enjoy owning one of these z cars. I am a chevy guy and not too knowledgeable on japan engines. It has the original 6 cyl eng with the turbo set up original. i have a few engines available. 406 stroked with dual carbs and aa nast cam. This one ran in the 9 sec range in a corvette. but, i was going to install it into my 280zx but am thinking i will need to backhalf the car to handle the torque of this engine. Also have a rather stock sbc 350 with a nice little cam and no real racing options. My question is in your experience which one would you recommend and why? Second question is where can i find the necessary parts needed? ive been all over the interweb and jtr is where i always end up. But is there someone who has some better mounts? I have a full s10 v8 swap kit and i beleive they are very similar. I would need to find a trans crossmember on its own in that case any ideas where i can find these parts? Thanks, BOLO Quote Link to comment Share on other sites More sharing options...
383z Posted February 6, 2014 Share Posted February 6, 2014 hey grumpy im new to this site and was looking around for an answer to my speedometer problem. i have a 383 stroker in a 84 300zx with a 350 trans and was wondering if there was a cable that will hook up from the 350 to the stock speedometer (its a analog, not digital ) or if it wound be easier to just buy new gauges and make a custom cluster. i also have an issue with my tires hitting the headers when turned too much any idea how i could fix that without spending a lot of money on new headers? Quote Link to comment Share on other sites More sharing options...
gunsaler111 Posted May 4, 2014 Share Posted May 4, 2014 Dear grumpy, What are your thoughts on quench and turbocharging,with a sbc? Quote Link to comment Share on other sites More sharing options...
