proxlamus© Posted September 22, 2008 Share Posted September 22, 2008 Quick question... when installing a battery cut off switch.. Do I wire this up to the POS + terminal or the NEG - terminal? silly question but I really don't have a clue Quote Link to comment Share on other sites More sharing options...
johnc Posted September 22, 2008 Share Posted September 22, 2008 Positive is typical. You want to stop all power from flowing through the car in case something grounds in a wreck. Quote Link to comment Share on other sites More sharing options...
Evan Purple240zt Posted September 22, 2008 Share Posted September 22, 2008 NHRA requires positive cable cutoff. Evan Quote Link to comment Share on other sites More sharing options...
proxlamus© Posted September 22, 2008 Author Share Posted September 22, 2008 Awesome. thanks guys!! Quote Link to comment Share on other sites More sharing options...
heavy85 Posted September 23, 2008 Share Posted September 23, 2008 There was a thread a while back on same subject. Definitely two sides of the fence on this issue. Cameron Quote Link to comment Share on other sites More sharing options...
Tony D Posted September 23, 2008 Share Posted September 23, 2008 The shutoff breaks the circuit to the source of power most likely to cause problems after a shunt...in most cases this is the battery. Sanctioning bodies have their reqirements, and if you are going to compete, follow their notations to the letter. Most cars will not function properly with a simple disconnect switch on the positive alone, it will require a secondary set of contacts to disconnect the alternator.For storage purposes, maintenance disconnect or 'theft provention' either would likely work as well. Quote Link to comment Share on other sites More sharing options...
Evan Purple240zt Posted September 23, 2008 Share Posted September 23, 2008 I bought one of these awhile back, had to search ebay to find it. http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&sspagename=STRK%3AMEWNX%3AIT&viewitem=&item=150216583279 It has the second set of contacts for the alternator field wire. Evan Quote Link to comment Share on other sites More sharing options...
