how do i tell what kind of gears are in my rear end
I still have a stock rear end in my 260z,
but i'm gonna put in another from one I parted out and in that car It did 90 mph in 4th gear
@ 5000 rpm's
Thanks in advance?
Hmmm not sure on the MPH thing but if you open the case there are set of numbers on the ring gear... you just divide the 2 and that gives your rear end gear. if i could remember the numbers id give you an example. just take the cover off and turn the diff with something till you see numbers. i thing there is a / in there somewhere cant remember been a while ;
Guest zthang43
I have a 3.56:1 (or something close to that) in my Z, it turns 4000 at 80 in top gear. Sounds like if you have smaller tires you probably have the same gear as me. It seems like the most common one from my experience. I was using 205/60/15's. Now I've got 245/60's in the back, looks way better and dropped a few hundred rpm on the freeway.
