TrumpetRhapsody Posted September 28, 2008 Share Posted September 28, 2008 I just ordered everything I need to get Megasquirt going (hopefully), and included one of the 6 3/4" 36-1 trigger wheels. I searched around Hybrid, but didn't see mention of anyone using one on a L6 motor. I was looking at my balancer today, and didn't see anywhere to bolt it on, so I'm wondering if I just wasted $30. http://www.diyautotune.com/catalog/361-trigger-wheel-p-181.html Quote Link to comment Share on other sites More sharing options...
jeffer949 Posted September 28, 2008 Share Posted September 28, 2008 why do you need the trigger wheel? why not just use the distributor? Quote Link to comment Share on other sites More sharing options...
TrumpetRhapsody Posted September 28, 2008 Author Share Posted September 28, 2008 I'm going to be running EDIS, which needs a trigger wheel. Probably should've mentioned that. Additionally, I don't have a turbo dizzy with a CAS, so that's not an option either. Quote Link to comment Share on other sites More sharing options...
Noddle Posted September 28, 2008 Share Posted September 28, 2008 I done my wheel like this http://noddle.110mb.com/EDIS/index.html but it's not one from diyautotune.com Nigel Quote Link to comment Share on other sites More sharing options...
Six_Shooter Posted September 28, 2008 Share Posted September 28, 2008 TrumpetRhapsody said: I'm going to be running EDIS, which needs a trigger wheel. Probably should've mentioned that. Additionally, I don't have a turbo dizzy with a CAS, so that's not an option either. You did mention that in the title. What balancer do you have? I know of at least two different balancers used on the L6, one that came on my '73 that I would assume would be the original balancer and one that was on the '81 ZX. Both have bolt holes that could be used for bolting the EDIS wheel on. The early balancer of mine has two bolt holes 180* apart, while the '81 balancer has 6 bolt holes that were used for a power steering pulley. Did you look at the trigger wheel installation tech articles on DIYautotune? Might shed some light on installing on your engine. Quote Link to comment Share on other sites More sharing options...
cygnusx1 Posted September 29, 2008 Share Posted September 29, 2008 I just finished my EDIS install using a 280Z pulley. http://forums.hybridz.org/showthread.php?t=136906 Quote Link to comment Share on other sites More sharing options...
TrumpetRhapsody Posted September 29, 2008 Author Share Posted September 29, 2008 Thanks guys, that tells me that I can at the very least FIND a dampener that will work for me. Quote Link to comment Share on other sites More sharing options...
TrumpetRhapsody Posted September 29, 2008 Author Share Posted September 29, 2008 Looks like tapping into the "meat" is the best way afterall, since the slots could cause the wheel to move and "wobble" with vibration at high rpm. So much for that, lol. Quote Link to comment Share on other sites More sharing options...
