Z-Dreamer Posted September 29, 2008 Share Posted September 29, 2008 Found this while researching for a propane conversion. Seems like a nice turn-key setup. http://www.technocarb.com/index.php?option=com_content&task=view&id=26&Itemid=84 Apparently Technocarb can build any size 4bbl carb for your system. Here is an interesting LPG tank design that should make a conversion easier. http://www.icomnorthamerica.com/toroidal.html Mark Quote Link to comment Share on other sites More sharing options...
Hotrodpez Posted September 29, 2008 Share Posted September 29, 2008 Those work REALLY well, I've seen them at use on sand dune monsters at Glamis. No fuel slosh, no pump needed, no starvation. Only downside (for a daily driver) is the lack of propane filling stations. I would look into using removable propane cylinders like forklifts do, so you could have one or two at home as spares. P.S. Some people complain about the smell of burnt propane. Go to Home Depot and smell their forklifts. If you're okay with your car smelling like that, the go ahead! Quote Link to comment Share on other sites More sharing options...
Z-Dreamer Posted September 29, 2008 Author Share Posted September 29, 2008 Found a vendor selling this 810 CFM, 800 HP "kit". http://autoparts.rasoenterprises.com/product_info.php?cPath=3_38_32&products_id=68 Mark Quote Link to comment Share on other sites More sharing options...
Tony D Posted September 30, 2008 Share Posted September 30, 2008 Only downside (for a daily driver) is the lack of propane filling stations. That's not really a downside...if you are commuting youcan easily locate two or three stations and fill as required. The real downside to Propane is for the guys that live up north. At -40 there is no tank pressure. The propane goes fluidic, and unless you supply heat to the tank, you won't likely get any tank pressure unless it warms up. THAT is a REAL downside. 4bbl would work well on the available manifolds! Quote Link to comment Share on other sites More sharing options...
PanzerAce Posted October 2, 2008 Share Posted October 2, 2008 So.....what kind of mileage do you get, and how much per gallon/liter Quote Link to comment Share on other sites More sharing options...
Daeron Posted October 7, 2008 Share Posted October 7, 2008 So.....what kind of mileage do you get, and how much per gallon/liter Short Answer is good enough, but not so good its gonna change the world. Quote Link to comment Share on other sites More sharing options...
