Guest 1fastz Posted January 25, 2002 Share Posted January 25, 2002 I will let you know how I do. I put solid ujoints in both half shafts lets see if they will hold up Quote Link to comment Share on other sites More sharing options...
denny411 Posted January 28, 2002 Share Posted January 28, 2002 Did ya make it to the track? how`d they hold up? Good/Bad/Better than the others? Quote Link to comment Share on other sites More sharing options...
jap tin Posted January 29, 2002 Share Posted January 29, 2002 Did you find the next weakest link ? Quote Link to comment Share on other sites More sharing options...
Guest 1fastz Posted January 29, 2002 Share Posted January 29, 2002 sorry for the dleay the track was rained out.. Im going to go tomorrow and I will let you know.. I also put a two stage kit on it now.. leaveing the line on a 100 shot then sparying 250 more after second gear instead of just the 350 in first i used to spray I think I will lay down some good times Quote Link to comment Share on other sites More sharing options...
denny411 Posted January 29, 2002 Share Posted January 29, 2002 I`ve got my fingers crossed Quote Link to comment Share on other sites More sharing options...
Guest 1fastz Posted February 1, 2002 Share Posted February 1, 2002 Broke the torque converter .. will post new numebrs when its replaced and i can pull a real run .. car ran a 10.3 @135 banging at 7 k all the way down Quote Link to comment Share on other sites More sharing options...
Guest jens Posted February 11, 2002 Share Posted February 11, 2002 Here is a pic of darius`s axles. Looks like a big universal u-joint and a r200/r230 cv-joint http://www.gatewayzclub.com/articles/darius/DSCF0020.JPG Quote Link to comment Share on other sites More sharing options...
Guest 1fastz Posted February 12, 2002 Share Posted February 12, 2002 where can i see that setup .. and is it substantialy stronger ? Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted February 12, 2002 Share Posted February 12, 2002 i am currently having a conversion to 930 Porsche cv`s . it is going in my 510 . however as i am going to be using custom sway away axels, a z would just need slightly longer axels. http://photos.yahoo.com/sss510six . Quote Link to comment Share on other sites More sharing options...
Z-Dreamer Posted February 12, 2002 Share Posted February 12, 2002 Hey that's what I want! I got the CV halfshafts with my LSD R200 and since the axles would have to be narrowed to work anyway... I really like the CV/U-joint combo. Can anyone tell me how it was done? More Darius PICS please!!! I'm gonna need it with a projected 550HP flywheel SBC in the mix! Mark Quote Link to comment Share on other sites More sharing options...
Modern Motorsports Ltd Posted February 12, 2002 Share Posted February 12, 2002 "I got the CV halfshafts with my LSD R200 " Mark, do you mean 300ZXT CV's or 280ZXT CV's? The 280ZXT CV's can be bolt in thru use of a CNC adaptor Scottie pioneered and I now offer. They tolerated Scotties power and I think we're all curious to see how they do at potentially higher levels (although I honestly didn't think we'd be seeing so many Z's with projected higher hp levels! ). Quote Link to comment Share on other sites More sharing options...
Guest jens Posted February 12, 2002 Share Posted February 12, 2002 Here is the pictures http://www.gatewayzclub.com/articles/darius/ Theres one there its possible to see the u-joint adapter. Its a r230 rearend and cv axles. The universal u-joints is welded on the r230 axles. Ask a driveshaft/axle expert he knows there to buy such parts. A ingieneer also has catalogs with industry u-joint parts with torque specs. Quote Link to comment Share on other sites More sharing options...
Guest 1fastz Posted February 12, 2002 Share Posted February 12, 2002 That setup looks like it would work awesom.. Just ptu a r-230 and then get the half shafts made.. Does anyone know how to get ahold of darius? email etc.. I would love to get some info from him . I can fab up mouting for the r 230 I just need to know if those outer half shaft ujoints are larger then the factory ones.. my prohblem is i snap them like candy.. If i can get that system and put a transbrake on the car it should be no problems for me to dip into the 9.0s or 8s with more nos. Quote Link to comment Share on other sites More sharing options...
John Scott Posted February 12, 2002 Share Posted February 12, 2002 Doing a little research, when you blow a u joint 1/2 shaft, where is it breaking? Is the body of joint itself coming apart or is it due to bearing bind in the cap of the u joint? Also sorry for the ignorant question, but what is the preferred model/year for the cv joint axle replacement w/adapters? 280zxt? Thanks! JS Quote Link to comment Share on other sites More sharing options...
Guest 1fastz Posted February 12, 2002 Share Posted February 12, 2002 I break them through the body of the ujoint.. I have also twisted the round ears OFF the half shaft without breaking a u joint.. its time to build something stronger Quote Link to comment Share on other sites More sharing options...
Guest 1fastz Posted February 12, 2002 Share Posted February 12, 2002 cv joints are WEEKER then u joints.. they just can withstand more angularity.. simple fact. my rear end is almost level with no angle when going down the track under load so the regular joints are actualy stronger for me then a cv. Quote Link to comment Share on other sites More sharing options...
Guest chevsun Posted February 12, 2002 Share Posted February 12, 2002 I am hopeing the cv"s will help my breakage problems. I had severe squat so I changed to #250lb coilovers and cv,s. If this doesn,t work I will go solid axle for sure I am sick of this breaking game. Quote Link to comment Share on other sites More sharing options...
stony Posted February 12, 2002 Share Posted February 12, 2002 1 fastz I have a 9 inch for sale with 35 spline moser axles... you could get 15 (also for sale) inch tires under the car with this rear end ;> if you still have no cage this may be a good option for you. launch on the bottle draggin the bumper ;> http://cgi.ebay.com/ebaymotors/aw-cgi/eBayISAPI.dll?ViewItem&item=602141573&r=0&t=0&showTutorial=0&ed=1013660273&indexURL=0&rd=1 http://cgi.ebay.com/ebaymotors/aw-cgi/eBayISAPI.dll?ViewItem&item=602142536&r=0&t=0&showTutorial=0&ed=1013660982&indexURL=0&rd=1 Quote Link to comment Share on other sites More sharing options...
Z-Dreamer Posted February 13, 2002 Share Posted February 13, 2002 Ross C, the CV's are the 300ZX Turbo's that came with my $45 LSD . I was hoping to use these axles by either shortening them ( retaining the inboard and outboard CV's) or using the "Daruis Solution". I'm atempting to build the strongest and most effective setup I can afford! With my head/cam/intake/exhaust specs I'll need it! Mark Quote Link to comment Share on other sites More sharing options...
Modern Motorsports Ltd Posted February 13, 2002 Share Posted February 13, 2002 "Ross C, the CV's are the 300ZX Turbo's that came with my $45 " I haven't confirmed it myself but someone has told me that the Z31 CV shafts are longer than the 280ZXT CV's and thus any spacer enabling you to use the Z31 shafts unaltered would either be really thin or one would have to shorten the shafts. Drop me a line personally to compare CV shaft lengths if you want. mailto:rossc@shaw.ca Quote Link to comment Share on other sites More sharing options...
