Administrators BRAAP Posted October 27, 2008 Administrators Share Posted October 27, 2008 Heres a Z32 with an L28 in it: http://www.race-cars.com/carsales/other/1062560599/1062560599ss.htm I dropped an L-26 into the engine bay of my Z-32 mock up mule in jest, showing how I was going to remedy all the labor intensive maintenance of the VG30DE… Didn’t realize someone actually did it! Cool! Quote Link to comment Share on other sites More sharing options...
JSM Posted October 27, 2008 Author Share Posted October 27, 2008 ... showing how I was going to remedy all the labor intensive maintenance of the VG30 That was my whole premiss around doing the swap. Who want's timing belts yuck! But I'm just weird that way. Quote Link to comment Share on other sites More sharing options...
Daeron Posted October 28, 2008 Share Posted October 28, 2008 I've got a L28et in a M30. I have to see this car...... thats been an idea of mine for QUITE some time. Send me a PM and lemme know when would be good for you, I am off on Mondays and Tuesdays and normally work afternoon/night shifts through the rest of the week, but I get short days.. Quote Link to comment Share on other sites More sharing options...
2eighTZ4me Posted October 28, 2008 Share Posted October 28, 2008 I dropped an L-26 into the engine bay of my Z-32 mock up mule in jest, showing how I was going to remedy all the labor intensive maintenance of the VG30DE… Didn’t realize someone actually did it! Cool! Wow Paul - that is ONE UGLY MULE!! Quote Link to comment Share on other sites More sharing options...
CamH Posted October 28, 2008 Share Posted October 28, 2008 I dropped an L-26 into the engine bay of my Z-32 mock up mule in jest, showing how I was going to remedy all the labor intensive maintenance of the VG30DE… Didn’t realize someone actually did it! Cool! That actually looks like it wouldn't fit all that bad. How did the clearances look underneath? Quote Link to comment Share on other sites More sharing options...
Administrators BRAAP Posted October 28, 2008 Administrators Share Posted October 28, 2008 That actually looks like it wouldn't fit all that bad. How did the clearances look underneath? It would take quite a bit of work for it to fit. Installed as is in the photo, oil pan resting on the cross-member, the front portion of the cam cover would protrude out of the hood. The cross member is pretty far rear rearward and wide, (front to back), with the rack attached at the rear of the cross-member. Firewall would have to be cut out to clear the upper portion of the bell-housing. Basically, it looks like everything that has been to the car regarding cutting, clearancing, etc, that has been for SBC Z-32 conversions is essentially what needs to be done for the L-6 to fit. Quote Link to comment Share on other sites More sharing options...
Administrators BRAAP Posted October 28, 2008 Administrators Share Posted October 28, 2008 Wow Paul - that is ONE UGLY MULE!! Yes it is UGLY!!! Functional for the job of V-8 mock up, YES! Aesthetically pleasing, NO! Currently has a bare SBC block in the engine bay to get an idea of what would be involved fro a quick and dirty conversion. Not liking the amount of cutting/clearancing needed to get the crank centerline to the OE elevation in the chassis and the shifter of the T-56 even remotely close to the OE location. With the SBC bell housing butted against the firewall, the T-56 shifter is still 2" forward of the OE shifter location and the crank centerline is approx 1 1/2"-2" higher than the VG30DE centerline using an OE SBC oil pan sitting ON the cross-member. Current plans are to install my VH45DE in the Z-32 with a scratch built intake to clear the hood use the Z-32 5 speed, (cringing....) Z-32's definitely are NOT as easy to HYBRID as the S-30! The MULE as I received it! Any how, lets get back to "L-6 in a Z-31"... Quote Link to comment Share on other sites More sharing options...
Administrators BRAAP Posted October 28, 2008 Administrators Share Posted October 28, 2008 Here is the thread with photos of a Turbo 2JZ inline 6 conversion in a Z-31, complete and running, and is wicked quick! http://forums.hybridz.org/showthread.php?t=133245 Quote Link to comment Share on other sites More sharing options...
Careless Posted October 28, 2008 Share Posted October 28, 2008 A buddy of mine in high school had a New, very early 84 300z. It had a L6 factory.Only 1 I ever seen. When I get home, I'll load up Nissan FAST and see if the engine mounts and oil pan exist =) Quote Link to comment Share on other sites More sharing options...
Careless Posted October 28, 2008 Share Posted October 28, 2008 I swear, I'm going to shoot myself in the face for putting money into my VG after seeing this thread. sure they're quite strong but I hate even having to go under there to drain the coolant from the block. *shudders* If it pops, I'm going to take my rebuilt+upgraded turbo and pop it on my L28E with megasquirt and toss it into the z31. Quote Link to comment Share on other sites More sharing options...
HowlerMonkey Posted October 29, 2008 Share Posted October 29, 2008 Remember that the vg30 has a crossover pipe and the stock intake manifold actually sit over part of the tranny bellhousing. This means you will probably have to move the tranny back for any straight six swap. Quote Link to comment Share on other sites More sharing options...
Careless Posted October 30, 2008 Share Posted October 30, 2008 I guess I might as well mention that the manifolds also leak at the head. And the flex joint in the cross over pipes always crack (look for black soot!). And in addition to that, it's not easy to remove the cross over pipe from the car without removing the passenger side manifol, as there are studs that get in the way and flanges with sleeves inside. In doing that, you'll find that there are broken exhaust studs once you pull off the passenger manifold. And then you can't even put a new gasket there because it won't seat properly. So then you end up like me, trying to take studs out for 2 weeks, only to find that there are 2 of them broken off on the passenger side head, and 3 of them broken on the driver side head. Try fixing that with the engine in the car. Here I am doing the pilot bearing job from hell, that's now turned into the "where are the bolts from this part" head-gasket job from the underworld. Quote Link to comment Share on other sites More sharing options...
HowlerMonkey Posted January 18, 2009 Share Posted January 18, 2009 L28et into M30 back on track for pic posting in a week or so. Made oil pick-up, dipstick, and used front dump from l24e first generation maxima as well as engine mounts from same car. Test fitted fine but am using built 3n71b and will be switching out m30 diff (w inch longer than other long snouts) for one with a more common length before solidifying driveshaft length. That means some tranny crossmember work. Quote Link to comment Share on other sites More sharing options...
JSM Posted December 13, 2016 Author Share Posted December 13, 2016 So HowlerMonkey how is your Z31 going? I just picked up an 88 Turbo with TWO popped head gaskets! I think he overheated it but he won't admit it. I'm planning a cross country road trip for my 50th birthday in 3 years. Gave myself a window to get her going. Quote Link to comment Share on other sites More sharing options...
HowlerMonkey Posted December 14, 2016 Share Posted December 14, 2016 I've put 55,000 miles on the Infiniti M30 since the L28ET replaced the VG30. I'm just waiting for something to break or I will simply keep on driving it. Quote Link to comment Share on other sites More sharing options...
JelmerPatrol Posted December 14, 2016 Share Posted December 14, 2016 The M30 has the same chassis as the Laurel C32/Skyline R31 so if you used a euro Laurel C32 with L24e subframe and engine mounts it would bolt right in. In europe we had L24e's until 1989. Quote Link to comment Share on other sites More sharing options...
JSM Posted December 15, 2016 Author Share Posted December 15, 2016 The M30 has the same chassis as the Laurel C32/Skyline R31 so if you used a euro Laurel C32 with L24e subframe and engine mounts it would bolt right in. In europe we had L24e's until 1989. I'm not well veresed on the Laurel C32/Skyline R31, but how does that apply to the Z31? Or are you making the reference to the M30? No worries either way. More curious then anything. Quote Link to comment Share on other sites More sharing options...
JelmerPatrol Posted December 15, 2016 Share Posted December 15, 2016 I have a C32 subframe which I can measure for you. It is from a LD28 powered C32. What dimenstions do you need? Quote Link to comment Share on other sites More sharing options...
HowlerMonkey Posted January 8, 2017 Share Posted January 8, 2017 (edited) The F31 chassis is a modified R31 with the engine bay being near identical and the rear half of the car being changed the most. The F31 does not have roll down rear windows and comes factory with the 280zx style rear suspension though it's possible that shock mounting points on control arms are higher or lower than on the 280zx. You can adjust the toe on M30 rear suspension. Even though the M30/F31/nissan leopard engine bay houses a single cam vg30 like the Z31, the dimensions of the bay are different concerning crossmember location and steering rack angle as well as steering shaft angle. This means the M30 crossmember in a Z31 will have bolt holes that don't match and also means that simply drilling new/extra holes might be a bad idea since the inside of the box sections of the frame rails have reinforcement where the crossmember bolts through. I would keep the Z31 crossmember, get a front sump L28 pan (1981 to 1983 maxima), and adapt the L28 for front sump pickup, Of course, you will also need to very carefully drill a new hole in the block for the dipstick. The M30 swap I did covers much of what is needed to do it to a Z31 except for turbo/downpipe clearance of steering shaft. The most important dimension is whether the L28 turbo itself clears the steering shaft of the Z31 but you might get lucky like in my M30 and find the turbo and factory L28 elbow clear it just fine. Since the L28et stock turbo has a two piece elbow, it's not hard to make a custom pipe with a 4 bolt flange that fits as well as getting rid of the two 90 degree angles used in the stock setup. On my previous 1984 L24 turbo maxima, I made this custom pipe and reduced the two 90 degree angles to two 45 degree angles. I guess I can try to fix up the thread posted here at some point. The biggest change was needing to lower the engine relative to the mounts (the rubber is stock L24 maxima mounts). I would fix the thread posted here at hybridz but ran out of patience with the forum software change a few years back. http://japanesenostalgiccar.com/forum/forum/garages/datsun-nissan-garage/7380-f31-build-leopard-or-infiniti-m30-with-l28et-swap It's a daily drive that does mid 14s in the quarter at 7.5psi on an untuned M30 ecu.........which runs 14.7 A/F ratio during daily driving and dips to 11.8 under boost with stock 280zx turbo injectors. I'm sure that the "under boost" will get leaner the more boost I throw at it but everything's perfect at this time though I would like a more turbo friendly timing curve. Edited January 8, 2017 by HowlerMonkey Quote Link to comment Share on other sites More sharing options...
Dramier Posted January 24, 2017 Share Posted January 24, 2017 I had an '85 300ZX Turbo with an RB25DET swapped in, first in the nation as far as we could ever determine back in 2004, and I would imagine the L28 swap would be a nearly identical setup. It was a fairly straight forward fit with the only major changes being a little bit of hammering on the transmission tunnel to get it to fit. Keep in mind there was a factory version of the car called a 200ZR in Japan that featured an RB20DET, so it's not really a far fetched concept. I no longer have my RBZ31 having stupidly traded it in 2008 due to lack of funds to keep it going and beginning a career. However I do know there is or was a guy named Racinjitter or something close to that who was also doing the RB25 swap and he should be finished by now. You might also refer to him and see if you can get some more background. I have never seen or heard of anyone with a Z31 with an L28 block in their car and I would have thought at some point along the way I would have definitely heard of it considering how many people contacted me over having an RB25 in mine. Doesn't mean there isn't one out there of course, just trying to be helpful. I will tell you I got a tons of hate from Z owners over the swap I did, and I just ignored them. Made me slightly biased against most of the Z forums from it as I got really tired of hearing the negativity after the car was finished. I don't know if that has changed these days since I don't visit anywhere except here and Nico club now, but if you do move forward with this project just be prepared for it. One other tidbit: I never successfully got the speedometer working with the RB with the Z31 digital gauges, but knowing what I know today about electronics having self-taught and learned a tremendous amount, I believe it wouldn't be that hard to get it to work. Good luck with your project if you decide to do the L28 swap and I think you will enjoy it more than the VG, I know I did. Quote Link to comment Share on other sites More sharing options...
