slownrusty Posted October 26, 2008 Share Posted October 26, 2008 I first did this install almost 8years ago and I have received numerous emails over the years from people asking how to do it...so here it is! I have run this set-up flawlessly for the past 8years and continues to serve me on my fairly significant L28 L30 Turbo build. It takes 15minutes, 16minutes if you are sipping a Heineken or beverage of choice. No special tools needed. 300ZX Turbo coil still one of the best out there! $10 from your local Pick 'N' Pull, make sure and get the coil with the factory bracket and harness, if you do not have it, go back and get it! This is the factory barrel coil, there is only one wire to it, a blue wire with a bullet connector labelled (1) in red and the factory "T" connector which is the signal to the Tach labelled (2) and has a rubber connnector over it. In this pic, you can see I already mounted the 300ZX Coil, how you mount it is strictly your preference and creativity. All factory conenctions removed, the blue wire with the bullet connector and the "T" copnnector for the tach signal (has two wires, a blackwhite wire and a yellow wire). You only need three wires from the 300ZX harness, labelled below: (3) Splice on a Spade connector (black white wire) (4) Splice on a a Spade connector (blue wire) (5) This wire connects to the factory blue wire with the bullet connector, I made a wire with a bullet connector on one end and a spade connector at the other end (in case I wanted to go back to the stock coil, which I never would). All connected: (1) connects to (5) (3) and (4) go into the factory T connector, match the blue wire to the yellow wire and the black and white wires to each other If your Tach does not work, you mixed up your T connector wires. 15minutes, $10 no special tools and you have a nice hot modern spark! Hope that helps. Now stop bothering me and sending me emails on how to do this...just kidding!! Glad to help out - anytime! Yasin Quote Link to comment Share on other sites More sharing options...
blu240z Posted April 14, 2009 Share Posted April 14, 2009 can you send me pics of the coil swap they were deleted Quote Link to comment Share on other sites More sharing options...
RUZN Posted April 15, 2009 Share Posted April 15, 2009 yes if I could get a Picture of this it would be great cause theres a 300zx in the wrecker full of parts even a good engine lol Quote Link to comment Share on other sites More sharing options...
240adam Posted May 20, 2009 Share Posted May 20, 2009 Bump, can you put the pics back on PLEASE! Quote Link to comment Share on other sites More sharing options...
Challenger Posted May 20, 2009 Share Posted May 20, 2009 Ditto, pics please. Does this work on all l28ets? Is a hotter/stronger spark the only benefit? Quote Link to comment Share on other sites More sharing options...
slownrusty Posted May 21, 2009 Author Share Posted May 21, 2009 Ok here are the pics again! Thsi works on all L28 engines regardless E or ET and it is a significantly hotter spark and more compact design. I am believer in this conversion. Regards -Yasin Quote Link to comment Share on other sites More sharing options...
240adam Posted May 22, 2009 Share Posted May 22, 2009 Thanks Alot, now I hope I can get spark with my turbo swap. Everything is hooked up right, but no sparky. I grabbed a coil from maxima its the same thing, but it has one extra black wire any idea what that one is for? Quote Link to comment Share on other sites More sharing options...
240adam Posted May 22, 2009 Share Posted May 22, 2009 Also, I am following Asfins write up on installing a Z31 ecu and it says to run a wire from the pos side of the coil to pin 34 and a wire from the neg side to pin 3. What would I conect those to on this new style coil? Thanks!!! Quote Link to comment Share on other sites More sharing options...
GrayZee Posted May 22, 2009 Share Posted May 22, 2009 I just noticed this post, very nice helpful info.. I have used this swap as well with success. I would like to point out that other coil ignitors can also be used if that one is not readily available. Lately I have been using a Nissan ignitor with 3 wires. They are found on many models.. Pathfinder, 240sx, Sentra, D20 truck, Access.. probably others as well. One wire goes to the ecu, one to the coil negative, and the last one is grounded. Quote Link to comment Share on other sites More sharing options...
Kash Posted October 22, 2011 Share Posted October 22, 2011 Can someone who have this running right post up a diagram? Quote Link to comment Share on other sites More sharing options...
HowlerMonkey Posted November 13, 2011 Share Posted November 13, 2011 When I pull a coil/igniter from a later model nissan, I also track down the small condensor that is in the harness a foot or so from the coil assembly. Quote Link to comment Share on other sites More sharing options...
