Guest Anonymous Posted June 30, 2002 Share Posted June 30, 2002 Who knows ZX Turbo differentials ??? Ocbaar and I are looking at a non-running 1973 240 Z that is for sale with a reported 1983 Turbo ZX diff. The diff has cv joints and is a R200. It was raining ,so we did not jack it up to test for positraction.There is no finned diff cover.If this is a turbo diff: The question: Positraction? gear ratio?? I did a search and discovered that the zx CV shafts mate to the 240 stub axles without flange adapters as is required with bigger 280 stub axels. The seller appears to be on a mission to BF Egypt and may know less than I do.. The car has ZX rear disc calipers,early 4X4 Toyota front calipers, drilled rotars, front and rear adustable camber plates,coilovers (different and stiff), poly bushings, strait and rust free.And of course we are looking for a price advantage to the $450. asking figure. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted June 30, 2002 Share Posted June 30, 2002 So a 1983 Turbo ZX did not come from the factory with a limited slip differential? and a 3.54 gear ratio? Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted July 1, 2002 Share Posted July 1, 2002 I dont think we saw any LSD's untill 86? maybe im wrong... ;/ flux Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted July 1, 2002 Share Posted July 1, 2002 Were the LSD diffs introduced in 1986 or 87 in the 300ZX model ?.... I just got off the phone and Ocbaar just bought the car for $350.00. And it does not have a LSD. He now has a good start on a 350/SBC Hybrid Quote Link to comment Share on other sites More sharing options...
blueovalz Posted July 1, 2002 Share Posted July 1, 2002 The R200 will not come with a LSD in this model from the factory. Not sure about the gear ratio though. Keep in mind that if the owner has already done all this other work to the car, you may even get lucky and find a pleasant surprise in the differential too. Who knows. Quote Link to comment Share on other sites More sharing options...
Brad-ManQ45 Posted July 1, 2002 Share Posted July 1, 2002 3.54 Quote Link to comment Share on other sites More sharing options...
Mike C Posted July 1, 2002 Share Posted July 1, 2002 The LSD showed up mid 1987 through 1989. They were a clutch type except for the '88 SE limited edition cars that were all white. I've heard different things about what year they switched to the 12mm ring gear bolts. I first heard '82 then I heard '85. Quote Link to comment Share on other sites More sharing options...
Guest KraZ4spd Posted July 5, 2002 Share Posted July 5, 2002 I have the same set up on mine. I do believe that you have a 3.54 ratio on your diff. wich will work good on your car with a V8. Quote Link to comment Share on other sites More sharing options...
