electrical and altenator problems
eightytwoturbo
hey all, havent posted in a while... got a question
there is 3 plugs that go into my ecu on my ZXT but there is also another coming off the harness near those 3 that is not plugged up... and i cant find where the hell it goes... is this a boost sensor plug or what? the wires are solid green and black. its a 2 prong plug i believe looks kinda like a "L" shape female connectors
anyone?... im trying to get my car to run right, been through all the normal z bs... cleaning every connection and ground, all my lights are on (fuel, brake, engine, door,) what the heck could be causing this? my idle jumps from 200-1000 and then the car dies. i was thinking a bad ground somewhere, but ive checked and cleaned everything... car was running superb till on my way home from work today.
not sure where this plug goes, but since its right near the ecu im guessing its well needed???
What do you mean "none of my belts are turning over"? Does the motor start / run? Does it crank? Can you move the clutch fan?
And the Haynes manual has all the maintenance / repair info you could think of (of download the FSM from http://www.xenons130.com). There's no need for an alternator removal write up... it's easy. You can remove it from the top (remove power steering pump) or from the bottom (remove skidplate). Two bottom bolts, and one top one... and wa-la, it's out!
motor will start and run with lumpy idle and then wants to go dead without some throttle pressed.
just got from up under it, seems like the bearing around the shaft of the fan coming out the head or whatever is busted, with oil around it, still not sure what it is so far, but not looking good.
and yes, none of my belts are turning over, even my radiator fan
my mechanic buddy is coming over soon to help me out, will keep ya posted
well ended up being my crankshaft pulley... its broke where the key holds it in place.
the bolt and washer came completely off that holds it on the front of the pulley :o
luckily the bolt and washer was laying in my fan shroud!
so im going to be buying a new pulley and crankshaft seal tommorow and putting it back together, im assuming this threw my timing off... so im gonna have to check my firing order. it would crank up previously and sounded normal, just a bad idle. so maybe nothing is internally screwed.
will update tommorow.
unless you moved the distributor or changes the sparkplugs around or the timing chain messed up then your timing is fine........that crankshaft pulley just drives your alternator, waterpump, powerstearing, a/c.....and probably the only reason its running ruff is cause of your alternator not charging.....which has been said 3 times.....why ask questions if your not gonna listen?
i know the alternator isnt charging, its because the crankshaft pulley isnt even moving, because its fucked... I am not asking questions now man, i was just wondering if that threw my timing off with the crankshaft pulley broke, since the shaft was constantly turning with nothing holding it tight onto the pulley because i drove it a little ways home, but decided to pull over and get it towed.
I am listening so i dunno wtf you mean by that.
my issue is solved now, the whole reason before was i thought i had a electrical wiring problem but ended up to be the altenator, but its not the altenator it self... its the crankshaft pulley which turns my altenator, waterpump, powerstearing, ac etc.
No flaming here, i appreciate all the help.
ok anyone have a resource online on getting a pulley and the seal that goes into the timing cover? do i need a whole new timing cover just because that seal came out? it looks like it was made onto the cover on the inside.....
oreily's parts here in town says its $240.00 for just a PULLEY to fit my car.. figured there would be some universal ones?? what the hell lol.
i dont mind using a used one in good shape
