DuoWing Posted December 18, 2008 Share Posted December 18, 2008 Alright I was trying to search on here, didn't find anything. Maybe I wasn't searching right. I tried to do some searching on google, but I couldn't find a definitive answer. I have a 76' 280Z 2+2 that I'm most likely going to just go ahead and run with. I want to do a basic suspension upgrade. I'm planning to go with the Tokico Illuminas, but I'm unsure of the springs. My Z31 is running front and rear illuminas with the eibach springs which I like. I also see that MSA at least sells Tokico springs. I've heard some people say the Tokico's would be better as they're made for the tokico's, but then I read that the springs aren't actually made by Tokico. Anyway some have said the Tokico ones will give you better handling because they're a set stiffness, where the progressives will give you a softer ride, and still handle well once you start to get on them, but supposedly the Tokcio's will be best for handling because they don't change. There's not a big price difference, and I'm thinking about just running the eibachs as I like them, but I figured I'd see what you guys have to say about them. Quote Link to comment Share on other sites More sharing options...
timbo1jz Posted December 23, 2008 Share Posted December 23, 2008 I have always liked eibach springs on the cars that I have ran them on. You might not get as much of a drop, but they will probably last longer and resist to sagging better than the Tokico springs. I do think that Tokico makes a great shock though. Quote Link to comment Share on other sites More sharing options...
EMWHYR0HEN Posted December 23, 2008 Share Posted December 23, 2008 If this is a progressive rate spring it probably won't make a difference which ever one you go with. Quote Link to comment Share on other sites More sharing options...
JMortensen Posted December 23, 2008 Share Posted December 23, 2008 If you search "tokico eibach" the first 7 or 8 hits are directly related to your question. Quote Link to comment Share on other sites More sharing options...
johnc Posted December 23, 2008 Share Posted December 23, 2008 Either spring is fine for your application and spring sag won't be an issue for at least 25 years with the Tokicos or Eibachs. I list the spring rates for the Tokicos on my web site. Quote Link to comment Share on other sites More sharing options...
