azZdriver Posted December 28, 2008 Share Posted December 28, 2008 How do you set the timing on an '82 280zxt? The Haynes manual says to see dealer. Does the 82 also have the Timing Adjustment Screw? I couldn't find it, but the crank angle sensor is inside the distributor so doesn't seem like it would be. Quote Link to comment Share on other sites More sharing options...
nismopick Posted December 29, 2008 Share Posted December 29, 2008 Weird... my Haynes manual has the specs on page 26. 20* +/- 3* @ 650-700 RPM. You adjust it just like any other car with a distributor. Loosen it, & adjust w/ timing gun. On the turbo model, you unplug the TPS while adjusting. The n/a model you disconnect the vac advance. EDIT... there is a VERY detailed step by step procedure on page 45. Quote Link to comment Share on other sites More sharing options...
azZdriver Posted December 29, 2008 Author Share Posted December 29, 2008 Note: This procedure does not apply to Turbo models. For 1981 Turbo models refer to Step 17. For 1982 Turbo models see your dealer. Is there a difference between turbo models? Quote Link to comment Share on other sites More sharing options...
nismopick Posted December 29, 2008 Share Posted December 29, 2008 Note: This procedure does not apply to Turbo models. For 1981 Turbo models refer to Step 17. For 1982 Turbo models see your dealer. Is there a difference between turbo models? See Step 17: It is possible the timing can go wrong if the crank angle sensor becomes misaligned. The CAS is located @ the front of the engine, alongside the crankshaft pulley. 81 turbo has a CAS on the crank pulley. The 82-83 CAS is in the distributor. Again... adjust timing like any other dizzy car. Quote Link to comment Share on other sites More sharing options...
(goldfish) Posted December 29, 2008 Share Posted December 29, 2008 http://carfiche.com/manuals023/cars/ FSM answers all. Quote Link to comment Share on other sites More sharing options...
azZdriver Posted December 29, 2008 Author Share Posted December 29, 2008 thanks guys Quote Link to comment Share on other sites More sharing options...
