which fuel pump
inlawZ
i've searched for hrs and i've realized that everyone will have a different ideas or preference. So, here's what i am doing:
71 240z w/ l28et
60mm tb
stock l28et ecu and wiring
stock l28et fuel pump
stock l24 gas tank
new aluminum fuel line (3/8)
garrett t3 turbo (from 300zx)
supra fmic
1g dsm bov
this is for a weekend car, maybe a daily
since i am using the stock l24 tank i will be putting in a surge tank. my question is which is the most recommended/affordable fuel pump that i could use for the surge tank?
also, which filters are the best to use with this setup? from all the searches it looks like it should be:
fuel tank -> filter -> low pressure/high flow fuel pump-> surge tank->filter-> turbo pump-> aluminum fuel line-> fuel rail
return line-> surge tank -> fuel tank
I think he is talking more abought the lack of baffeling in the carbed tank. I am running a walbro 255 on my factory 260z with my car. If I am going to drive crazy I just make sure I have over a half tank. I dont have a big problem with starving the fuel pump till I suck a good 7-8 gal out of it. The factory fuel pump should flow enough for right at 300hp - 300tq if its in good shape.
I had a clogged line feeding my fuel pump on my 75. so I drained the gas tank, and drilled and tapped the stock drain port to a 1/4 npt thread. Then installed a 90 degree-3/8 hose barb fitting. Put on a clear plastic puralator filter with 3/8 barbs and mounted a fuel pump at the level of the tank bottom. works great until 1/4 tank, then I get fuel issue if I do quick changes in speed or direction. A 240 has a similar drain plug.
The efi stock pump should work fine. A 2225 msd efi pump will also work well for cheap (90.00 to 100.00).
use the old tank feed line as the return line.
don't use aluminum fuel lines.
the return line needs to be the same size or bigger than the feed line.
