liveforeverZ Posted February 13, 2009 Share Posted February 13, 2009 Hey guys, The clutch on my 280 is frozen stiff. It moves maybe a cm or 2. Any ideas? Quote Link to comment Share on other sites More sharing options...
batou Posted February 13, 2009 Share Posted February 13, 2009 have you bled the system? could have a bad clutch master, slave, or even fork, throwout bearing, clutch plate. Start with the easy stuff. Quote Link to comment Share on other sites More sharing options...
liveforeverZ Posted February 13, 2009 Author Share Posted February 13, 2009 Thanks. Car has been sitting for an awful long time. Gonna try the slave first. Brake and clutch systems are always my downfall and least confident areas. Would a bad slave keep the pedal high and not let it depress? Quote Link to comment Share on other sites More sharing options...
Jesse OBrien Posted February 14, 2009 Share Posted February 14, 2009 Thanks. Car has been sitting for an awful long time. Gonna try the slave first. Brake and clutch systems are always my downfall and least confident areas. Would a bad slave keep the pedal high and not let it depress? It certainly could. With hydraulic lines, if there's a pressure buildup anywhere, you really won't be able to budge the pedal (unless the blockage has some play). Bleed the system and refill it. It's worth it, especially if it's been sitting. If that doesn't do the trick, drain the trans oil and replace it. Check for flakes or chunks of metal in the oil. If you find either, it's likely that you'll need to tear the trans down to find out the offending piece of metal. If it STILL won't budge, you're going to have to detach the trans from the engine and take a look at the clutch assembly. I'm not familiar enough with the little Nissan transmissions to be able to say for sure, but I see plenty of misaligned clutches that refuse to move. Like batou said, you may need to dig a little bit deeper to check on the clutch fork and throwout bearing. Everything else should be fairly easy to inspect. Quote Link to comment Share on other sites More sharing options...
theghosttanker Posted February 14, 2009 Share Posted February 14, 2009 Unbolt the slave cylinder from the transmission housing and leave the hydraulic line connected. Now try to depress the clutch pedal. If you can't, you'll know that the problem is in the master, slave, or hydraulic line. If you can, then you have to pull the tranny and see what's wrong inside the clutch housing. The problem is most likely going to be in the slave cylinder, which is great since they are CHEAP. (get one from Rockauto.com for 12 bucks) There is no reason to drain the transmission fluid and check for chunks as drummingpariah suggests. This is a clutch problem. Quote Link to comment Share on other sites More sharing options...
liveforeverZ Posted February 14, 2009 Author Share Posted February 14, 2009 Thanks, will do. 280z service manual is on the floor and open to slave cylinder. Quote Link to comment Share on other sites More sharing options...
Jesse OBrien Posted February 14, 2009 Share Posted February 14, 2009 ...there is no reason to drain the transmission fluid and check for chunks as drummingpariah suggests. This is a clutch problem. No worries, I was just tossing ideas out. Quote Link to comment Share on other sites More sharing options...
liveforeverZ Posted February 17, 2009 Author Share Posted February 17, 2009 Thanks guys, it turned out to be the slave. As soon as I went under, it looked like the rod was bent, so I took it off, and not only was it bent, but it was stuck shut. Ordered one from Napa today for 12$, gonna put it in tomorrow. While I was taking off the slave, the withdrawal lever dust boot crumbled off. I've called everyone and can't find one - is it possibly listed as something else? No one at the parts desks seem to know what I'm talking about when I say withdrawal lever. Quote Link to comment Share on other sites More sharing options...
Trevor Posted February 23, 2009 Share Posted February 23, 2009 "CLUTCH FORK BOOT" Look at Black Dragon's catalog, page 84, cost: $6.00 Quote Link to comment Share on other sites More sharing options...
