graphicjunkie Posted February 16, 2009 Share Posted February 16, 2009 I've got a lead on a 78 280Z rear differential. And I've read where the R200's are tough, checked the wiki from the board member to validate that it really would be a R200 not an R180... But I pretty much just want to hear lamens terms tell me that if I buy this R200, I can put up to 500ftlbs to it and it will handle it. Because I haven't seen any real threshold numbers for torque. Can someone humor me here and confirm what I have read, or correct me and save me the money? Thanks! Quote Link to comment Share on other sites More sharing options...
Administrators BRAAP Posted February 16, 2009 Administrators Share Posted February 16, 2009 I love Humor... Pretty good chance there is more than 500 ft/lbs of blown nitrous V-8 torque being put through this R-200, over and over and over again.... Vidoe of that car; Don't forget Zgads 240-Z... http://videos.streetfire.net/video/ZGad-2JZGTE-Powered-240Z_104277.htm Quote Link to comment Share on other sites More sharing options...
JMortensen Posted February 16, 2009 Share Posted February 16, 2009 If you're drag racing you might consider welding it or getting a limited slip of some kind. The cross pin is the thing that fails on the R200. If you're not drag racing you should be fine I think. Quote Link to comment Share on other sites More sharing options...
graphicjunkie Posted February 16, 2009 Author Share Posted February 16, 2009 Yea, after I posted that, I started to dig into this forum, as I don't spend as much time here as I do the V8Z forum. I just got done watching a video and reading a couple of other threads. Was going to come back here and post a 'never mind'...but you beat me. Here's what I am about to go buy... Complete front & rear suspensions & brakes with Eibach performance rate coil springs, kyb struts,suspension techniqes THICK anti roll bars (almost double the size of the stock ones), all those parts were on a 78z for just over 6 months. Included extras are rear diff. for a 5 speed w/new isolater, rebuilt 1/2 shafts, rebuilt drive shaft, steering rack, moustache bar w/urethane mounts. $350! I'm not really a drag racer, because the cost to race around here anymore is REDICULOUS! Almost $100 a day, and you MIGHT get in three runs.... I'll definately look into welding the cross pin if that's a fail point. Thanks for the input! Quote Link to comment Share on other sites More sharing options...
ZXT_bean Posted February 19, 2009 Share Posted February 19, 2009 thats just insane!! Quote Link to comment Share on other sites More sharing options...
jnjdragracing Posted February 20, 2009 Share Posted February 20, 2009 Need to check out our youtube videos of the new engine combo Blown Alky injection. Search youtube for jnjdragracing and watch the testing new project videos. Talking about put the little R200 to the test..... John Quote Link to comment Share on other sites More sharing options...
FlatBlack Posted February 20, 2009 Share Posted February 20, 2009 jnj - in the video that Braap posted you let off everytime the car lifted, have you found any solutions to that? [And here we have a good example of how there CAN be too much horsepower ] Quote Link to comment Share on other sites More sharing options...
jnjdragracing Posted February 20, 2009 Share Posted February 20, 2009 Yep we found the solution, change the engine...... My brother is putting together another Nitrous motor and I am looking for an alky carb to try also and just leave the blower off for now. If both of these fail to come about we will be putting weight up front and possible wheelie bars on back. Probably run a timer also that will be triggered at a certain point to retard my timing about 10 degrees and then when it settles down it will kick it back in. The Zcar will be in paint and body prison for awhile. This will give us somethime to determine what we are going to do. John jnj - in the video that Braap posted you let off everytime the car lifted, have you found any solutions to that? [And here we have a good example of how there CAN be too much horsepower ] Quote Link to comment Share on other sites More sharing options...
FlatBlack Posted February 20, 2009 Share Posted February 20, 2009 Sounds like a monster. Was there any front end damage? Quote Link to comment Share on other sites More sharing options...
jnjdragracing Posted February 20, 2009 Share Posted February 20, 2009 The front support that the rack / steering bolts to is bent some. I guess it is from the bunch of abuse from the front end hitting. I have a hook welded under the car on that support which is longer than the oil pan etc. All the hits that hook has taken has bent that support / brace. Other than that no other damage........ We do run a front motor support and a mid-plate motor support, along with baddog framerails. Also the 10 point cage, so the whole car is tied together pretty well, no flexing etc.... John Quote Link to comment Share on other sites More sharing options...
jnjdragracing Posted February 22, 2009 Share Posted February 22, 2009 Yep we found the solution, change the engine...... My brother is putting together another Nitrous motor and I am looking for an alky carb to try also and just leave the blower off for now. If both of these fail to come about we will be putting weight up front and possible wheelie bars on back. Probably run a timer also that will be triggered at a certain point to retard my timing about 10 degrees and then when it settles down it will kick it back in. The Zcar will be in paint and body prison for awhile. This will give us somethime to determine what we are going to do. John John, you forgot to mention the twin turbo setup, I will be making some changes to the rear suspension, to keep the car from hitting the tires so hard. ( leaving so hard) The car put down a 1.31 60' tripping the timers with the back tires. John, will be painting, and I will be working on the rear suspension, getting it ready for PINKS ALL OUT, and DNI in Renolds,G.A. Jerry Quote Link to comment Share on other sites More sharing options...
