Why the Noise?
A loud knocking noise occurs inside my right rear strut on my 260z when ever I hit a bump. I had new struts installed and the noise started then. any solutions? Also I had new rubber installed on the rear suspension and since then the rear end squeaks going over bumps. Does any one know how to make it quit?
Thank you!
i had a problem similar to this on my front struts. Installed some tokico hp shocks along with eibach springs. heard a light thunking when i hit small repeated bumps. finaly narrowed it down to the shock hitting the gland nut on rebound. took it apart and put the spacer that tokico provided in and no more thunking.
I dont know if thats your problem but its an idea to check.
Were the "bump"stops installed? As mentioned earlier there is also a spacer that goes between the shock and the gland nut. They reccomended something like 5-6mm gap between the strut tube and top of the gland nut when torqued to 90 ft/lbs. I bet it could be slapping around in the strut tube.
Thanks for all your good advise! I took the strut assembly apart just as Jimbo and lowrider said. I found that the inside rubber spacer was destroyed and allowed the shock end shaft to hit on the cap assembly (the one with the 3 nuts on top, inside of car. I am waiting on delievery of the rubber spacer!! Thanks again for all your input.
