stony Posted June 27, 2015 Author Share Posted June 27, 2015 Haha your funny.... its a straight downpipe with 4 in Dia staight muffler that is about 6 inches long. It dumps right after the front wheel. Entire thing is about 2.5 feet long Quote Link to comment Share on other sites More sharing options...
stony Posted June 27, 2015 Author Share Posted June 27, 2015 Looking at doing a side pipe. Quote Link to comment Share on other sites More sharing options...
stony Posted June 27, 2015 Author Share Posted June 27, 2015 You can see my exhaust leaning against the wall in this pic ;> Quote Link to comment Share on other sites More sharing options...
stony Posted June 27, 2015 Author Share Posted June 27, 2015 Quote Link to comment Share on other sites More sharing options...
aongch Posted July 4, 2015 Share Posted July 4, 2015 What are your goals again for this build - drag, road race/tracking? Nice build and progress! Keep em coming, I'm following... Quote Link to comment Share on other sites More sharing options...
stony Posted July 6, 2015 Author Share Posted July 6, 2015 Drag racing a street cruising. Should see in excess of 750 to the wheels. in a 2300 lb car.... that is fun. Quote Link to comment Share on other sites More sharing options...
stony Posted July 11, 2015 Author Share Posted July 11, 2015 Well got the 91 Oct tune close. 18 Psi feels real good. the reg gas sounds so much different then the E85. Much angrier at idle. Quote Link to comment Share on other sites More sharing options...
flatrate Posted July 11, 2015 Share Posted July 11, 2015 Pump gas sounds angry?? I think the additional fuel required with E85 makes the injectors work in a more desirable range, not sure what size your using, but anything under like 1.2ms at idle generally causes it to be a bit erratic, and that's with the new latest and greatest bosch ev14's You can counter act that some by opening the throttle plate more at idle allowing more air in.. if it idles to high pull timing back down to reduce idle speed.. just don't pull to much otherwise it will run hot at idle. Quote Link to comment Share on other sites More sharing options...
stony Posted July 11, 2015 Author Share Posted July 11, 2015 Using bosche 1600. When i say angry i just meant its louder and more loapy. With e85 it seems to run quieter and idle smoother. Quote Link to comment Share on other sites More sharing options...
stony Posted July 20, 2015 Author Share Posted July 20, 2015 Granted this has a different down pipe but here is an example of what i mean by more angry. Exact same build, only difference is gas type. Gas (106 unleaded) https://youtu.be/A42jkjinJO4 Vs e85 https://youtu.be/qu_HpSQ6rms Quote Link to comment Share on other sites More sharing options...
ZT-R Posted July 21, 2015 Share Posted July 21, 2015 First one kinda sounds like my neighbors boat Quote Link to comment Share on other sites More sharing options...
stony Posted August 1, 2015 Author Share Posted August 1, 2015 well finally making the leap to the 2j side. rb is if sale. only reason is I came across a steal of a deal on a complete 2j that I couldn't pass up. Quote Link to comment Share on other sites More sharing options...
flatrate Posted August 4, 2015 Share Posted August 4, 2015 SMH, not mad just disappointed Quote Link to comment Share on other sites More sharing options...
stony Posted August 4, 2015 Author Share Posted August 4, 2015 I know I know. It's all in the interest of cheaper speed. Quote Link to comment Share on other sites More sharing options...
flatrate Posted August 7, 2015 Share Posted August 7, 2015 Meh, 2J's arent that cheap... Not when your already setup into an RB Quote Link to comment Share on other sites More sharing options...
stony Posted August 7, 2015 Author Share Posted August 7, 2015 Well considering I can go to just about any of the five pick in polls in my area and grab a long block for a hundred and fifty bucks... That's cheaper than in RB Quote Link to comment Share on other sites More sharing options...
stony Posted August 10, 2015 Author Share Posted August 10, 2015 Before the build i wasn't even starting to build any boost till 5500rpm. Now I'm getting 10 PSI at 4600 and full boost (12 psi right now) at 5200!!! Im, hoping with some more tuning i can get it going a little earlier and N20 will be a thing of the past ;> https://youtu.be/3z_CA2RI2R0 Quote Link to comment Share on other sites More sharing options...
Sovereign Z Posted August 10, 2015 Share Posted August 10, 2015 Video says private Quote Link to comment Share on other sites More sharing options...
stony Posted August 10, 2015 Author Share Posted August 10, 2015 Should be good now. Quote Link to comment Share on other sites More sharing options...
