L28et turbo flywheel
J240ZTurbo
The turbo flywheel has a 240mm contact surface (vs the 225mm stock) so you can run a larger clutch disc. If you're planning on running a 6puck or 4puck, I don't think it really matters which one you run, as neither of those clutch discs use the entire potential clutch surface. If you're going to run an organic disc you will gain a little more surface area, and you can run the 280zx turbo pressure plate.
40$ is a very good deal.
