nsm27 Posted March 23, 2009 Share Posted March 23, 2009 I'm new to this forum and I'm a bit stuck. I've been rebuilding an 81 280zx coupe back to an every day driver, but I don't want it to feel like a cadillac anymore. As for the rear suspension, are there any good upgrades that are out there, either off the shelf or something that can be fab'd up that will limit the amount of float I get from the rear sub frame to the body mount? The rubber isolators between the sub frame and body are all worn out. I was thinking of replacing with solid steel spacers and leave all the suspension movement up to the shocks and lower trailing arm. Is that a bad idea or what...any help is greatly appreciated! Quote Link to comment Share on other sites More sharing options...
nismopick Posted March 23, 2009 Share Posted March 23, 2009 Welcome to the forum! There's lots of info here... just gotta do a quick search... or look at the sticky threads. http://forums.hybridz.org/showthread.php?t=114631 Quote Link to comment Share on other sites More sharing options...
tec280zx Posted March 26, 2009 Share Posted March 26, 2009 I modified some energy suspension subframe bushings from a Z31 to fit my crossmember. Just have to trim them a bit to make fit. Quote Link to comment Share on other sites More sharing options...
JMortensen Posted March 26, 2009 Share Posted March 26, 2009 I modified some energy suspension subframe bushings from a Z31 to fit my crossmember.Just have to trim them a bit to make fit. That's a good one. Racers usually have aluminum bushings made so that there is zero flex in there, of course that basically solid mounts the diff, so it makes it noisy inside. Also slotting the rear crossmember for camber and toe adjustment is a good idea. These are the race type upgrades. The main thing that will make it feel less like a riding LaZBoy is a spring and strut upgrade. If it is a street car and you're just looking for a firmer ride, start there. Quote Link to comment Share on other sites More sharing options...
woldson Posted March 26, 2009 Share Posted March 26, 2009 The main thing that will make it feel less like a riding LaZBoy is a spring and strut upgrade. If it is a street car and you're just looking for a firmer ride, start there. Very true. I did this on my zx's rear and what a difference. The stock stuff should mabe be on a metro. Quote Link to comment Share on other sites More sharing options...
nsm27 Posted March 26, 2009 Author Share Posted March 26, 2009 thanks for all the input. I've got everything out now, so I'd like to do it all now and leave it for the future. I like tec280zx's upgrade. I have one question though. when you modify the urethane part, do you set it up so that the sub frame rests on the urethane on the top and bottom at the same time the lower attachment nut is tightened into the frame of the car? The stock set up has a gap left at the top and bottom when the lower attachment nut is tight leaving the rubber to dampen out the motion / noise when it rotates to the extreme. If that is the case, then I'm all good to go. Again, thanks for all the input you guys are great! Quote Link to comment Share on other sites More sharing options...
