garvice Posted April 2, 2009 Share Posted April 2, 2009 Yep, as above, just keep it waxed. You can get aluminium anodised with a finish called "Bright Anodising" though, and it is extremely bright. That will hold up better then polish and waxing, especially for outdoor gear. Quote Link to comment Share on other sites More sharing options...
WhiteHorizonZX Posted April 3, 2009 Share Posted April 3, 2009 Beau M said: What is it about this design that makes me think of... And why do I foresee some horrible outcome? Quote Link to comment Share on other sites More sharing options...
Beau M Posted April 3, 2009 Author Share Posted April 3, 2009 Have faith, you are on the right track. I think I can pull it off. Quote Link to comment Share on other sites More sharing options...
slown280z Posted April 3, 2009 Share Posted April 3, 2009 If you want this part MADE out of basically any kind of metal, I know someone that might be able to cut it out on CNC machinery. How much were you looking to spend? Quote Link to comment Share on other sites More sharing options...
Beau M Posted April 3, 2009 Author Share Posted April 3, 2009 I will let you know after I try and make a set Quote Link to comment Share on other sites More sharing options...
WhiteHorizonZX Posted April 4, 2009 Share Posted April 4, 2009 I can tell you from personal experience with metals.... You're better off making this from 1/8" aluminum. Quote Link to comment Share on other sites More sharing options...
gjc5500 Posted April 4, 2009 Share Posted April 4, 2009 It looks like one of those "JDM" tow hooks you see on hondas all the time. Want to see finished product with lights. Quote Link to comment Share on other sites More sharing options...
RJ280ZX Posted April 10, 2009 Share Posted April 10, 2009 give me some more dimensions and I can have this part made for you. Quote Link to comment Share on other sites More sharing options...
jerryb Posted April 10, 2009 Share Posted April 10, 2009 Just to help clear something up. You cant just buy a Chrome piece and make something out of it. You would need to buy a piece of steel , make the part and then send the finished piece to have it chromed. A somewhat expensive task because they would need to polish the piece to a luster before chroming. And you will not work harden SS when drilling it. Drill with slow RPM and use lots of lubricant, otherwise you will burn up your cutter. Most home drill presses dont go nearly slow enough to cut SS...I know ....I found out the hard way! It also depends on the grade of SS and lots of metalurgical mumbo jumbo....anyway, it doent matter for a trim piece that takes zero load of any sort. Correct me if Im mis-understanding but this is a decorative application...not functional so your primary concern is appearance? SS may be the best option for a trim piece. It can be purchased with a brushed, matt or polished finish. It even comes with a protective plastic film to prevent scratching during the manufacture of the part. Best part is , SS will not tarnish like AL. Beau M said: Also, do you reccomend chrome, or stainless steel? Quote Link to comment Share on other sites More sharing options...
Beau M Posted April 10, 2009 Author Share Posted April 10, 2009 Thanks for the tips. I know I would have to have it chromed after the part was made, but with SS I was worried about getting discoloration on the cut edges. I'm still a ways off from making these things. Quote Link to comment Share on other sites More sharing options...
jerryb Posted April 10, 2009 Share Posted April 10, 2009 No probs...There will be zero SS discoloration if you cut at the right speeds...slow. Beau M said: Thanks for the tips. I know I would have to have it chromed after the part was made, but with SS I was worried about getting discoloration on the cut edges. I'm still a ways off from making these things. Quote Link to comment Share on other sites More sharing options...
auxilary Posted April 16, 2009 Share Posted April 16, 2009 maybe this? http://www.emachineshop.com/ Quote Link to comment Share on other sites More sharing options...
Beau M Posted April 16, 2009 Author Share Posted April 16, 2009 Thats awesome. I'm going to request a quote. Quote Link to comment Share on other sites More sharing options...
Beau M Posted April 17, 2009 Author Share Posted April 17, 2009 So I used the software, I really like it. To have two of those made from .05" aluminum is 190 bucks shipped. Yowza. Quote Link to comment Share on other sites More sharing options...
