georgiaz Posted February 7, 2003 Share Posted February 7, 2003 How do I tell if my 75 280 has a limited slip diffirential or positraction? Tire smoke maybe? I'm not driving it yet. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted February 7, 2003 Share Posted February 7, 2003 Jack the rear up. Take car out of gear. Turn one wheel. If the other wheel moves in the opposite direction, no lsd or posi. If is moves in the same direction, you have lsd or posi. Mark Quote Link to comment Share on other sites More sharing options...
Mike C Posted February 7, 2003 Share Posted February 7, 2003 Unless it is a damaged open diff, or a worn out limited slip. Positraction is GMs trade name, TrakLok is Dana's and Traction Lock is Ford's. They all mean the same thing, Clutch pack limited slip. Only way to know for SURE is to pull the cover... But since the LSD is most uncommon, I would assume that you have reason to believe you might have one? If that is the case, then most likely Mark's method will confirm/deny that. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted February 7, 2003 Share Posted February 7, 2003 Most open diff's can put down 2 black marks from a dead stop, so the smoke thing will not work Best way is what Mark said. Tom Quote Link to comment Share on other sites More sharing options...
johnc Posted February 7, 2003 Share Posted February 7, 2003 Take the cover off! I know I sound like a broken record, but that's the ONLY way you will know of you have a limited slip. The spin the wheels, turn the driveshaft, or burnout tests will not tell you if its a welded diff, a LSD, or if some guy has filled the unit with sawdust and 140W gear oil. Take the cover off! Quote Link to comment Share on other sites More sharing options...
Pop N Wood Posted February 7, 2003 Share Posted February 7, 2003 Isn't it also true the torque biasing diffs (like the Quaiffes) will look like an open diff with the wheel test? Quote Link to comment Share on other sites More sharing options...
Mike C Posted February 7, 2003 Share Posted February 7, 2003 Yes. With no torque to speak of as you rotate the tire, no bias. Quote Link to comment Share on other sites More sharing options...
georgiaz Posted February 10, 2003 Author Share Posted February 10, 2003 Guys, slow down please, you'r leaving me. I'm showing my ignorance here, but I'm not sure what to look for if I did pull the cover. I did run it down the street the other day (first time and damn it's quick). I know you said it may not be a determining factor, but the right side tire does light up quite a bit more than the left. Doesn't the JTR manual say that the posi-traction was standard? Quote Link to comment Share on other sites More sharing options...
Guest TBroZ Posted February 10, 2003 Share Posted February 10, 2003 Please, please don't say "posi-traction". In essence, you're asking if it has a General Motors limited slip differential...which I really doubt. Quote Link to comment Share on other sites More sharing options...
Guest 240hybrid Posted February 10, 2003 Share Posted February 10, 2003 georgia Z...when you pull the rear cover, turn the gear until you see some numbers. should be an equation to calculate out that will give you your ratio. example 37 x 11= 3.36 gear ratio. Hope this helps. Chase Quote Link to comment Share on other sites More sharing options...
johnc Posted February 10, 2003 Share Posted February 10, 2003 No US 240/260/280Z came with a limited slip diff from the factory. The LSD was (and still is) available from Nissan Comp. Here's some info about the Nissan Comp LSD and what to look for when you take the cover off: http://www.gordon-glasgow.org/lsd1.asp Quote Link to comment Share on other sites More sharing options...
Tim240z Posted February 10, 2003 Share Posted February 10, 2003 Originally posted by 240hybrid:georgia Z...when you pull the rear cover, turn the gear until you see some numbers. should be an equation to calculate out that will give you your ratio. example 37 x 11= 3.36 gear ratio. Hope this helps. Chase Chase,Should be 37 divided by 11. Small oversight, I'm sure Tim Quote Link to comment Share on other sites More sharing options...
