Oil pan??
  • Administrators
I'm assuming you mean for your 240-Z. The truck pan will physically fit but the sump is quite low and if the car is lowered the sump will drag the ground. The F-bod pan seems to be the most popular. I have heard that a few have successfully used the Vette bat wing pan.
http://ls1tech.com/forums/conversions-hybrids/817787-lsx-oil-pans.html
Edited by BRAAP
I didn't know this is a 2 pieces pan. The one I used is the same thing but from a 98 model and it's a one piece. I had to cut the wings and cap them to work in the Z. With the wings you will have no room to run the exhaust. Also I don't think you can cap the 2 pieces pan. GL
  • 4 weeks later...
