randy 77zt
30-1 tooth wheel with cherry hall effect sensor
Going back a few posts, I hope you didn't just plug in the numbers I posted for my wheel. They would only work if your missing tooth was exactly the same as my wheel (highly unlikely).
MS will pick up the RPM no problem since you told it's a 30-1 wheel (30 teeth, gap -1) but the spark will be all crazy because the coil firing positions are wrong.
Share this post
Link to post
I dialed in my tooth seperation but still no dice
I think its in the config of the coils to plugs
thanks Lancevance: that helped for sure
Been swamped at work this week so may give her some love this weekend
I also might buy an FR-S tomorrow, it may or may not be related to my car troubles haha  :wink:
Edited by MaTTSuN
Share this post
Link to post
Ok let me try to get this all in one post, I have some time tonight to go through all my notes
attached is a picture of my last routing of my coils to plug set up
also i attached how i wired the coil to relay board and coil drivers to the MS pcb
the missing tooth @ TDC is 18
Last i tried i had my trigger settings at
A Pos      13
    Return 17
B Pos       23
     Return 27
C Pos       3
    Return  7
I tried moving them around in incriments of one but could not find the right pattern
The version of my MS is MSnS-Extra Format 029q
any ideas guys? Sorry for taking so long the FR-S is a nice little car so havent been thinking about the datsun much.
I am excited to feel real power again with all the upgrades i just did :-)
Edited by MaTTSuN
Share this post
Link to post
Your wheel settings look fine, but your coil wiring is still screwy. The coils should be paired 1+6, 2+5, 3+4. It looks like you have plug wires on 1+4, 2+6, 3+5.
I modified DIY's picture for that coil and how yours is mounted upside down in your car, it should look like this:
That's front to back ABC.
Edited by Metro
Share this post
Link to post
cool, ill try that coil set up when i get home
just to be on the same page, this is correct right?
Share this post
Link to post
so i tried to start it with the same resault
It looks like i already had the plug wire routed the right way  A 1,6 B 2,5 C 3,4
Here are some pics of my relay board wiring to coil
the green wire is switched power
Does this look right?
Share this post
Link to post
On second thought, I might be leading you astray here. My ignitors aren't mounted on the MS board, they're inside a GM DIS coilpack where the GM ignitors used to be. MS just outputs a spark logic signal, not the coil grounds. I guess how you wire the output of your ignitors is up to you, if they're on SP2, 3, 4.
Share this post
Link to post
Im going through my notes right now, Looks like everything is wired up right
Relay output          MS pin out
S1==============25
S2==============27
S3==============29
S4==============31
S5==============36
If everything is right here then ill have to double/triple check my missing tooth to TDC but im pretty sure thats on as well
Then back to the Trigger settings
Share this post
Link to post
lookig even closer haha looks like my wiring is wrong
 Relay Board to coils wires
Current                 Correct
S3 RED               S5 RED
S4 BLUE             S3 BLUE
S5 YELLOW       S4 YELLOW
Looks like i messed up in my notes pairing it all together on paper
Ill try it when i get home... hope she fires
Share this post
Link to post
well i swapped the wires and it seamed to be close, just sounds like the timing is off but it still does not run
I think its all settings in MS now
Ive only had small amounts of time to get tests in but ill look at the trigger wheel again and dive into the trigger settings again
it may be time for a degree wheel, Once i get it set ill make a summery of all my settings and hook ups :-)
Silver lining is that the wideband seams to have stop having error8 :-)   Disconnecting the battery for a few weeks must have re-set it
Share this post
Link to post
