streeteg Posted June 2, 2009 Share Posted June 2, 2009 I purchased a guage used however it only came with teh sensor and not the bung that is welded on the exhaust pipe. Does anyone know what size bung to get or where to purchase? I have looked all over.. Quote Link to comment Share on other sites More sharing options...
dsommer Posted June 2, 2009 Share Posted June 2, 2009 Right here at Summit Racing. If you have every thing else just source a bung from a local muffler shop. http://store.summitracing.com/partdetail.asp?autofilter=1&part=ATM%2D5249&N=700+115&autoview=sku Quote Link to comment Share on other sites More sharing options...
streeteg Posted June 4, 2009 Author Share Posted June 4, 2009 Thats for the whole sending kit-- i just need the actual bung that welds on to the exhaust to fit it on. For some reason they wanted me to source my own...It was mufflex in NJ which is supposedly a really great shop-- Quote Link to comment Share on other sites More sharing options...
Turbo7MN Posted June 7, 2009 Share Posted June 7, 2009 I made one, just grabbed a piece of round stock off the shelf drilled it and tapped it. I'm sure summit or jegs can get you just the bung, if you can't find it (I couldn't) I'd call them. Quote Link to comment Share on other sites More sharing options...
trwebb26 Posted June 9, 2009 Share Posted June 9, 2009 http://store.summitracing.com/egnsearch.asp?Ntt=oxygen+sensor&N=700+115+4294859977&Ntk=KeywordSearch Quote Link to comment Share on other sites More sharing options...
trwebb26 Posted June 10, 2009 Share Posted June 10, 2009 Oh wait.. you said pyrometer... sorry... http://store.summitracing.com/egnsearch.asp?N=700+4294859977+115+400442 Quote Link to comment Share on other sites More sharing options...
Challenger Posted June 10, 2009 Share Posted June 10, 2009 Does anyone know what size bung to get or where to purchase? I have looked all over.. I made one, just grabbed a piece of round stock off the shelf drilled it and tapped it. I'm sure summit or jegs can get you just the bung, if you can't find it (I couldn't) I'd call them. I dont think he knows what size or thread it is. Do they make NPT taps? Quote Link to comment Share on other sites More sharing options...
bobbyc Posted June 10, 2009 Share Posted June 10, 2009 ive always used those spark plug spacers..antifowlers or soemthing like that... from autozone for all my bungs...just cut the lower portion off and weld the threaded portion on...i don't know what size or pitch you are lookin for..but it's worth a shot. Quote Link to comment Share on other sites More sharing options...
zxtman Posted June 10, 2009 Share Posted June 10, 2009 try here: http://tscsensors.com/bngwo0000250180compress.html Quote Link to comment Share on other sites More sharing options...
streeteg Posted June 10, 2009 Author Share Posted June 10, 2009 That is looking like the best option so far--- i jut have to make sure i got the right thread pattern on the autometer sensor Quote Link to comment Share on other sites More sharing options...
hughdogz Posted June 10, 2009 Share Posted June 10, 2009 That is looking like the best option so far--- i jut have to make sure i got the right thread pattern on the autometer sensor I hope you purchased the 0-1800F one. I tried the 1600F one and after sustained periods over 1600F, it is stuck there Quote Link to comment Share on other sites More sharing options...
drift_inertia Posted June 10, 2009 Share Posted June 10, 2009 just find a nut that fits the sensor thread drill a hole and tack weld the nut to your exhaust pipe?? it worked on an fc3s i used to own Quote Link to comment Share on other sites More sharing options...
WizardBlack Posted June 20, 2009 Share Posted June 20, 2009 What EGT probe did you get that has threads on the actual sensor? Most I have seen are installed via compression fittings like the link from zxtman. Quote Link to comment Share on other sites More sharing options...
drift_inertia Posted June 21, 2009 Share Posted June 21, 2009 Sorry if i described it wrong, my sensor didnt, have threads either. It was an autometer c2 egt gause the probe was about a 1/4 inch? thick of round stock that was bent into a 90 degree, i didnt have the fittings that came with it except for the the piece the sensor slid into. the piece the sensor slid into looked like a nut with a setsrec drilled into the side of it and abou 4 threads at the end. i found a nut that fit the threads and drilled hole in my exhaust spot welded the nut to the exhuast and installed the senor and piece i had. BUT I have also seen people take a drill bit the same size as the sensor,find a nut the right size to drill through and then weld the nut to the exhuast, drill hole through the nut and piping ,insert the sensor and the use a hose clamp to clamp it down by wrapping around the exhaust pipe and sensor. I only have experience with autometer egt's and sensors so i'm not sure if they are all 90 degree bend or not. Quote Link to comment Share on other sites More sharing options...
streeteg Posted June 22, 2009 Author Share Posted June 22, 2009 I will take pictures this weekend if the setup all works out Quote Link to comment Share on other sites More sharing options...
