speeder Posted June 17, 2009 Share Posted June 17, 2009 Check this out: http://forums.hybridz.org/showthread.php?t=96805&highlight=BAE It looks as if you don't have the silicone hose clamped well at the throttle body? Quote Link to comment Share on other sites More sharing options...
speeder Posted June 17, 2009 Share Posted June 17, 2009 Also, that noise is almost certainly an exhaust leak, from a single cylinder from the sound of it. I've also heard a head gasket leak that blows out the side sound like that. You can test that with a compression check. Quote Link to comment Share on other sites More sharing options...
turbojohnny Posted June 17, 2009 Author Share Posted June 17, 2009 ah, it must be the head gasket, we just did a compression test and 2 cylinders were low. looks like the head is going to come off. Quote Link to comment Share on other sites More sharing options...
turbojohnny Posted June 17, 2009 Author Share Posted June 17, 2009 Check this out:http://forums.hybridz.org/showthread.php?t=96805&highlight=BAE It looks as if you don't have the silicone hose clamped well at the throttle body? i didn't have the connection clamped at the throttle body, but that wasn't the source of the leak, i had pulled the j-pipe to clean it up a bit. Quote Link to comment Share on other sites More sharing options...
2Zowner Posted June 17, 2009 Share Posted June 17, 2009 wwoww...haven't seen one of those in a long time. I had one on my 76 Z a long time ago. I always had oil issues with it and those annoying little fuseable links thingy's...I will look thru my file. I might still have the booklet for the installation of the BAE turbo set-up. Mine was purchased and installed through Bob Sharp Racing back in 1979... Quote Link to comment Share on other sites More sharing options...
turbojohnny Posted June 17, 2009 Author Share Posted June 17, 2009 i think it's kinda cool having a vintage turbo setup, except the turbo is also blowing oil into the intake, so i might replace it soon, i just don't know what with, i don't want anything that i will have to highly modify the system to use. Quote Link to comment Share on other sites More sharing options...
speeder Posted June 17, 2009 Share Posted June 17, 2009 I might still have the booklet for the installation of the BAE turbo set-up. If you guys will follow my link in the post above you will find the complete BAE kit manual. I posted this for another guy years ago. Quote Link to comment Share on other sites More sharing options...
turbojohnny Posted June 17, 2009 Author Share Posted June 17, 2009 i did see your post, but i don't really need installation information, the system is already on the car. Quote Link to comment Share on other sites More sharing options...
turbojohnny Posted June 20, 2009 Author Share Posted June 20, 2009 ok so just to be on the safe sidei purchased a freshly rebuilt cylinder head. i figure if i'm going to have the engine apart i might as well put a fresh head on it. i'm also going to replace the original bolts with a set of ARP studs, as recommended. do you guys have any recommendations on a specific head gasket to use, or will any brand suffice? Quote Link to comment Share on other sites More sharing options...
kolonelklink87 Posted June 21, 2009 Share Posted June 21, 2009 ok so just to be on the safe sidei purchased a freshly rebuilt cylinder head. i figure if i'm going to have the engine apart i might as well put a fresh head on it. i'm also going to replace the original bolts with a set of ARP studs, as recommended. do you guys have any recommendations on a specific head gasket to use, or will any brand suffice? If you're going to the effort of getting a fresh head (investment much) why not throw in a little extra cash and start putting together a fresh bottom end to go with it? ie: replace the gasket on your current set up then put it back together. Then you can take your time putting together a proper beating heart for that thing without chopping and changing parts into a running vehicle? Way i understand it, l28 bottom ends aren't terribly expensive or difficult to find for you yanks? certainly not when considering the expense of a fully reconditioned head? Quote Link to comment Share on other sites More sharing options...
turbojohnny Posted June 21, 2009 Author Share Posted June 21, 2009 well i spent under $400 for the head, and the car only has 61k miles on it, so i'm not too worried about the bottom end, also i want to be able to drive the car! i'm not getting into pulling the motor and rebuilding the whole thing just because i'm already in there, no offense or anything. i just figured it'd be easier for me to pull the head and put on a fresh one as opposed to pulling the head and taking it to a machine shop to have it rebuilt, it would probably be about the same price. Quote Link to comment Share on other sites More sharing options...
rossman Posted June 21, 2009 Share Posted June 21, 2009 There are lots of threads about head gaskets on HZ. If it were mine, I'd use a Nissan gasket. Quote Link to comment Share on other sites More sharing options...
turbojohnny Posted June 21, 2009 Author Share Posted June 21, 2009 ok i'll keep searching around, any place other than a dealer where i can order an oe nissan gasket? Quote Link to comment Share on other sites More sharing options...
rossman Posted June 21, 2009 Share Posted June 21, 2009 I believe Motorsport Auto has them. I'm sure Courtesy Nissan has them for a reasonable price too. Quote Link to comment Share on other sites More sharing options...
kolonelklink87 Posted June 22, 2009 Share Posted June 22, 2009 ...also i want to be able to drive the car! i'm not getting into pulling the motor and rebuilding the whole thing just because i'm already in there, no offense or anything. actually that was my whole point- consider doing the HG to make it drivable, then get another block and bide your time putting together something special- a new topend deserves a new bottom end ... of course this mightnt be nessecary if those kms are "genuine" perhaps pull the head, inspect top and bottom ends- collect information then decide; it needs to be done to catch that gasket in any case i'm just tryna be helpful, lost money in the past buying parts before i was certain about the direction of my projects:redface: Quote Link to comment Share on other sites More sharing options...
turbojohnny Posted June 22, 2009 Author Share Posted June 22, 2009 well i guess it couldn't hurt to inspect things, but it is the actual mileage of the z, verified by all of the paperwork, and the tread life left on the tires that are still on the car from 1982! Quote Link to comment Share on other sites More sharing options...
rossman Posted June 22, 2009 Share Posted June 22, 2009 I agree, you should inspect the cylinders for scoring. When I pulled the head off my old setup (similar to yours), one piston had been replaced and there was deep scoring in 5 & 6. You never know. The PO told me it kept blowing head gaskets. Apparently he was having some severe detonation problems. An old inefficient turbo, lack of intercooler, high compression pistons and jerry rigged fuel system is a recipe for disaster if you're not careful. I considered water injection before I just ditched the whole thing after I found out the bottom end was trashed. Quote Link to comment Share on other sites More sharing options...
VQS13LUIS Posted June 25, 2009 Share Posted June 25, 2009 I would'nt waste my time with the bottom end...Just change the head gasket and drive it.. Its a very familiar sound to me..Blown head gasket... I do recomend new head blots ...by the way oem nissan hg and felpro (autozone or advanced ) hold out the same..anything after 22 psi they blow out... Quote Link to comment Share on other sites More sharing options...
Kash Posted June 26, 2009 Share Posted June 26, 2009 Blown exhaust gasket and get rid of those chimpian plugs before the Z police take your car. Quote Link to comment Share on other sites More sharing options...
turbojohnny Posted June 26, 2009 Author Share Posted June 26, 2009 i have the new ngk's sitting on my desk right here, the gaskets, p90 cylinder head, and ARP head studs are on their way. hopefully everything will be here by monday, and then hopefully by saturday i will register and insure the car! Quote Link to comment Share on other sites More sharing options...
