i want to replace my rajay!
I just picked up this car, and i've noticed that there is some blow by, so i have a healthy coating of oil on the inside of the j-pipe.
i want something that will bolt right up to my existing manifold, but making a new down pipe is not a problem for me.
my question is...
what is a fairly inexpensive, and readily available turbo to replace this with?
i'm not looking for big performance, just something to that will perform decently close to whatever this one did.
the 280z bae turbo kit used a j type coupler thing off of the na exhaust manifold. The 280zx kit had its own cast turbo manifold. the cast manifold has a t4 flange on it that had a exhaust opening that could of been opened up. So im assuming the 280z would have the same flange. So you need a t4 housing turbo or you need to get a t4/t3 adaptor and run a t3. I would just maybe suggest a rebuild kit. Check gpopshop.com they might have a rebuild kit for it.
  Sparky said:
Turbonetics bought rajay some time ago and may still have rebuild kits.
i looked into that, they no longer own rajay, and don't have anything left for rajay turbos, i also contacted kelly aerospace, who bought rajay from turbonetics, and they no longer make any automotive turbos.
