notheredave Posted June 20, 2009 Share Posted June 20, 2009 I was thinking of the Rover 4.2L aluminum V8 and (2) SETS OF zx9 40mm carbs (4X 40mm Keihin CV40 carbs). Then I did a search...here are some pictures. And they are cheap, plentiful and a lot of parts available. Quote Link to comment Share on other sites More sharing options...
tonycharger72 Posted June 20, 2009 Share Posted June 20, 2009 And has been installed into a Z as well!!! Think is the 3.5L though, This is from an Australian Z car website! http://www.zshop.net.au/Photos/Parts/ Quote Link to comment Share on other sites More sharing options...
deja Posted June 20, 2009 Share Posted June 20, 2009 From a cool factor I think it would be awesome. I think that engine was used in old Buicks from the 60's before it was sold to Rover. Quote Link to comment Share on other sites More sharing options...
notheredave Posted June 20, 2009 Author Share Posted June 20, 2009 tonycharger72 said: And has been installed into a Z as well!!! Think is the 3.5L though, This is from an Australian Z car website! http://www.zshop.net.au/Photos/Parts/ What happened to the front end? and I see that it was carb'ed...I think it's pretty much like installing a SBC. Quote Link to comment Share on other sites More sharing options...
notheredave Posted June 20, 2009 Author Share Posted June 20, 2009 deja said: From a cool factor I think it would be awesome. I think that engine was used in old Buicks from the 60's before it was sold to Rover. Yes I agree!!! COOOOOL I knew about the long history...and a lot of cheap parts avail. for those old motors...I am actually going turbo: http://forums.hybridz.org/showthread.php?t=149969 Quote Link to comment Share on other sites More sharing options...
grndfx Posted June 20, 2009 Share Posted June 20, 2009 I'm not 100%, but I think the all aluminum rover V8 is lighter than the L6. Allways thought it would make for an great swap. Quote Link to comment Share on other sites More sharing options...
ZROSSA Posted June 20, 2009 Share Posted June 20, 2009 The buick/rover is one of the lightest v8s ever made. Lighter then a lot of 4 cylinders. The heads are not that flash, make a bit of torque but not much hp. The later rover blocks are a much better place to start. I think they have 4 bolt mains and so forth. Douglas Quote Link to comment Share on other sites More sharing options...
notheredave Posted June 21, 2009 Author Share Posted June 21, 2009 grndfx said: I'm not 100%, but I think the all aluminum rover V8 is lighter than the L6. Allways thought it would make for an great swap. It still has me thinking...HMMMMMMMMMMMMMMM Twin turbo!!! Quote Link to comment Share on other sites More sharing options...
notheredave Posted June 21, 2009 Author Share Posted June 21, 2009 ZROSSA said: The buick/rover is one of the lightest v8s ever made. Lighter then a lot of 4 cylinders. The heads are not that flash, make a bit of torque but not much hp. The later rover blocks are a much better place to start. I think they have 4 bolt mains and so forth. Douglas There is a lot of information out there on mods...From the English Guys and others Quote Link to comment Share on other sites More sharing options...
kiwi303 Posted June 22, 2009 Share Posted June 22, 2009 www.v8forum.co.uk lots of RV8's in little light escorts pimped up with turbos and NOS doing trips down the 1/4 mile on there. Quote Link to comment Share on other sites More sharing options...
frank280zx Posted June 23, 2009 Share Posted June 23, 2009 Id stay away from anything rover 4.0 or 4.6 wise .. there notoriously bad they are overbored 3.5’s and the liners (needed due to the fact they are all aluminum, and not like the bmw v8s treated alumin) are way to thin causing them to slip… (read crack) so you can toss the engine .. it is not a question about IF they do it but WHEN.. This makes finding a good used one fairly hard and expensive ( $2000 and up) but new improved ones expensive aswel. And this is not all hearsay I Drive a Range Rover 4.6HSE as a tow vehicle … and im on my second engine.. I allmost dropped a chevy sbc in .. but there is no easy support for the electronics the Land Rover has plenty of. Quote Link to comment Share on other sites More sharing options...
notheredave Posted June 23, 2009 Author Share Posted June 23, 2009 frank280zx said: Id stay away from anything rover 4.0 or 4.6 wise .. there notoriously bad they are overbored 3.5’s and the liners (needed due to the fact they are all aluminum, and not like the bmw v8s treated alumin)are way to thin causing them to slip… (read crack) so you can toss the engine .. it is not a question about IF they do it but WHEN.. This makes finding a good used one fairly hard and expensive ( $2000 and up) but new improved ones expensive aswel. And this is not all hearsay I Drive a Range Rover 4.6HSE as a tow vehicle … and im on my second engine.. I allmost dropped a chevy sbc in .. but there is no easy support for the electronics the Land Rover has plenty of. That's good to know...So I could run the 3.5L turbo'ed? It's sounding like I should run a q45 v-8 LOL Quote Link to comment Share on other sites More sharing options...
