N42 intake mod and PCV port
darkzebra
I am modifying a non-egr N42 intake to install on my 82 280ZXT. Need to tap new PCV port on bottom of intake, since the original port is in the way of the turbo. Since the wall of the intake seems thin, is there a recommended position to tap this new port?
OK.
The new port is to be located 2" forward of the present PCV port, closer to the TB. Do I just drill and tap in the new location? Is it thick enough to get enough thread for the PCV to hold firm? Or do I need to have something welded to increase the thickness?
Guest Rolling Parts
Thanks!
I don't plan on using the heat shield
I simply tapped into the cold air intake instead of the manifold. 2 reasons: That way I'm assured of having only a vent(vacuum) on the crankcase and there is no chance of an air leak behind the AFM.
I tried running that nice, clean, pretty manifold without the heatshield. What happens is that the the injectors and injector wires get real hot because the turbo is right under them by less than a foot. I installed the heatshield!
  • Administrators
Yes, There is “just” enough material in the wall thickness of the plenum floor that you can drill and tap the bottom of the plenum to relocate the PCV valve to the same location as it is on the Turbo manifold. If you have the option to build up that region where you want to locate the PCV valve by welding it, by all means do so.
Here is one of my custom N-42 intakes that I drilled and tapped the bottom of the plenum for vacuum ports, (fuel pressure regulator, Brake booster, MAP signal for MS, etc). This was on my Race car for short period and now running on another HBZ members boosted L28. :wink:
  • Administrators
So you plumbed the PCV valve itself, (the breather tube for the engine block), to a point in front of the throttle body instead of behind it where it would see vacuum? Why bother?
I'll elaborate...
1) Just put a filter element on the block vent tube, serves the same purpose and gets rid of that unnecessary hose/plumbing to the cold air intake and no oily blow by being pumped through the AFM, and the rest of your intake tract! Ever notice the thick slimy oil residue on the inside of an intake manifold? That is how the rest of your intake tract, AFM, Turbo, inter-cooler if using one, will look after sometime with your crank case breathing into your cold air intake.
2) The PCV valve itself is a spring loaded valve designed for a vacuum atmosphere, i.e. intake manifold. The only portion of the intake system that experiences the vacuum a PCV valve is designed for is the air space between the throttle body butterfly and the intake valves. If plumbing your cranks case breather anywhere else, the PCV valve itself is not functioning as designed.
3) When using the PCV as it was designed, if you are concerned about the engine ingesting “false” or “un-metered” air, the OE PCV/vacuum plumbing eliminates that by allowing fresh filtered air from “behind” the AFM to be drawn in to the valve cover, (this air is metered by the AFM), and as it passes through the crank case is drawn into the bottom of the intake manifold through the calibrated PCV valve and burned in the combustion chambers. That air was measured by the AFM and the appropriate amount of fuel compensation is made by the ECU.
Hope that helps
Guest Rolling Parts
Sorry for the confusion.
I hoped that my post implied removal (not re-installing) the bulky PCV.
As aarang said, a small unobtrusive tap can be used instead.
I do plan on retaining the PCV valve so I will tap the heatshield mount boss.
I did not plan on installing the heatshield, neither on running the cooling fan for the injectors. Instead, I intend to jet-coat the exhaust manifold, and also wrap it. Would this compensate enough so that the injectors would not overheat?
Also, I notice a protrusion inside each runner at the injector end - one of the screws for the injector holder. Should I grind this down?
I just did this a few weeks ago. I just tried to match up really closely where to put the PCV on my N42 egr-less intake. I was trying to do a 90* fitting, but that still was against the turbo. So I just drilled a new spot for the PCV and used some pipe thread sealer. There's enough material as mentioned, although I did notice that spot for the heatshield. I agree with what others have said. It may not look as nice, but run the heatshield as it will help. Not to mention with the N42 there is no webbing to help dissipate heat under and out from the sides of the manifold. I just painted my heat shield with manifold paint. Looks nice. Also just use a 1/4" NPT pipe plug for the old PCV spot.
Guest Rolling Parts
That's a lot of cost and work and still does not address the turbo heat on shutdown. Removing the fan and heat shield are a double-whammy for increasing heat soak on the injectors and rail.
I hope it will work for you. I tried the super clean look but soon discovered that Nissan had a reason for simple fixes for a problem....
Well as for the coating and wrapping, I believe it was hughdogz that did this and he cracked his manifold it got so hot. Ill search for the post to confirm my memory.
Also those protrusions can be ground smooth, I cant see any reason it would harm performance and the screw hole doesnt break through.
I'm sure Nissan had a good reason for the fan and webbing, so if I have to keep the heatshield then I will.
Talk about the work - it ain't easy being 60 and arthritis and all, and using a damn file on the N42. And it seems the real fun now begins - my engine is in a running car, I did not plan on taking it out, and it seems real difficult to switch the intake and exhaust without taking it to a shop.
Those four bolts below the heat shield that go into the head dont "hold" the manifold on they just "hold" it on. If you remove the 4 bolts on the top of the manifold, two in the middle one on each end, make sure all the fuel lines and vacume lines are detached the manifold will pull strait up off the engine. The bolts you mentioned only wedge the manifold onto the engine, loosening only makes it easier to pull off.
It will feel like its impossible to pull off but it is possible. I actually used an engine hoist an a junkyard to pull it off it was on there so tight.
