bryand2 Posted August 19, 2009 Share Posted August 19, 2009 just got my car back from the shop and the turn signals arent working, they were working when i took it in, checked fuses already, any suggestions? Quote Link to comment Share on other sites More sharing options...
zedman240 Posted August 19, 2009 Share Posted August 19, 2009 Check all your globes and flasher can. i know if a globe is out, the system doesn't like it! What work was done? Quote Link to comment Share on other sites More sharing options...
bryand2 Posted August 20, 2009 Author Share Posted August 20, 2009 $6400 dollars worth of suspension work and some ecu re wiring Quote Link to comment Share on other sites More sharing options...
bryand2 Posted August 20, 2009 Author Share Posted August 20, 2009 globes and flasher can? im not really familiar with the electrical system Quote Link to comment Share on other sites More sharing options...
jhm Posted August 20, 2009 Share Posted August 20, 2009 Check your flasher relay. There are two mounted next to each other on the side panel underneath the dash (on the driver's side, just to the left of your left knee). One flasher is for your turn signal; the other's for your hazard lights. Very cheap to replace -- I just got a new flasher for my turn signal at Pep Boys for $2.99. Also check your bulbs. As Zedman mentioned, a burned-out bulb may sometimes cause system problems. Finally, check your connections under the dash. The two connection points that come to mind are: 1) the turn signal connection on your steering column (3-prong plug) and 2) the harness connections under the dash on the passenger-side. Ensure all connection plugs are firmly plugged in. Good luck and happy motoring. Quote Link to comment Share on other sites More sharing options...
bryand2 Posted August 27, 2009 Author Share Posted August 27, 2009 does anyone know if one turn signal bulb being removed will make the entire system fail? i removed one bulb that was burnt out before i put it in the shop Quote Link to comment Share on other sites More sharing options...
Daeron Posted August 30, 2009 Share Posted August 30, 2009 YES!!!! that is EXACTLY what they were telling you! Granted, our friend from Australia said "globes" instead of "light bulbs" but jhm said it in plain, american english.. Quote As Zedman mentioned, a burned-out bulb may sometimes cause system problems. Quote Link to comment Share on other sites More sharing options...
bryand2 Posted September 3, 2009 Author Share Posted September 3, 2009 ok well replaced the removed bulb and still no luck, the side markers and grill signals light up when lights are on, but no signals or flashers Quote Link to comment Share on other sites More sharing options...
Daeron Posted September 3, 2009 Share Posted September 3, 2009 There is a sticky at the top of this subforum titled Turn Signal/Hazard system or something along those lines. Read that thread through, it is a helpful read to anyone with an S30. i can't recall how deeply into specifics on the 280 system the thread got, but they were similar in design. If you do not already have it, google xenons30.com and find your model year's FSM; t6hat can only be of assistance to you. Quote Link to comment Share on other sites More sharing options...
Administrators BRAAP Posted September 6, 2009 Administrators Share Posted September 6, 2009 This Z car forum is more of an extreme performance Z car forum, a supplement to a shop manual for those projects above and beyond what a simple Haynes manual does not cover. This forum is not really a replacement for a basic service manual, again geared mostly towards extreme performance modifications, i.e. HybridZ. Even the simple cheap Haynes manual has good wiring diagrams for the car, as a Haynes manual is good investment, especially for problems such as troubleshooting electrical gremlins. Hope that helps, Paul Quote Link to comment Share on other sites More sharing options...
DuoWing Posted September 29, 2009 Share Posted September 29, 2009 In case you haven't figured this issue out. Here's my input. My dash lights, tail lights, parking lights, turn signals, etc were not working. I took apart the Hazard switch, cleaned it like in the write-up and put it back together. This helped my situation. I had some lights working. I checked my fuse for my parking lights. Even though it looked ok, when I pulled it out the fuse was old and falling apart. I replaced it and now my parking lights worked. I pulled apart the turn signal switch on the steering column and cleaned that up. It helped to improve my situation, but I still had issues. Finally when I replaced the flashers and all the bulbs everything worked as it should. One of my Flashers looked rusted as if water had gotten into it. It was causing my lights to do some strange things. Go through all of these steps. If this doesn't fix your issue then I'd say you may have a wiring problem. Quote Link to comment Share on other sites More sharing options...
