OSearcy4 Posted August 31, 2009 Share Posted August 31, 2009 ok for starters heres the car info Body - 97 Camaro V6 Engine - 93 Corvette LT1 ECM and wiring - 94 Z28 to start i have a 07 camaro v6 and i bought a 94 Z28 for the engine to do a swap. Long story short i had problems with the engine and it broke down. so i bought a 93 corvette engine and ecm. The place that installed the engine disassembled everything. here is all i know. I think they used the corvette block heads cam, etc bottom half. They used the 94 Z28 intake manifold fuel rails throttle body, etc top and front half. Now for the problems.... The engine does run, however not well. It doesn't have the power it seems like it should. The check engine light comes one when you crank the car however if the car is in drive and at a red light, the check engine light cuts off. The electric fans also kind of correspond to this. They cut on when you crank the engine and cut off at a red light but cut back on when you take off again. I think the issues are coming from the ecm and wiring. anyone who has any experience with ecm issues or any suggestions please email me OSearcy4@aol.com. I just want this car to run and run strong. I have dumped a lot of money into a good engine and it just doesn't go like it should. I can't get a code reader to read the ecm because i dont think the plug is wired right. i have both the obd1 and obd2 plugs and i've tried both of them. Anyone who has a shop near Auburn, AL please email me also i would be willing to drive close by just to have someone look at it. thanks. Quote Link to comment Share on other sites More sharing options...
hoov100 Posted August 31, 2009 Share Posted August 31, 2009 one question before this gets sent to the shed, why did you throw an lt1 in an ls1 camaro? Quote Link to comment Share on other sites More sharing options...
MAG58 Posted August 31, 2009 Share Posted August 31, 2009 I think it's an LT in a V6 camaro. But still, why did you pick HBZ for this question? Quote Link to comment Share on other sites More sharing options...
FlatBlack Posted August 31, 2009 Share Posted August 31, 2009 ok for starters heres the car infoBody - 97 Camaro V6 Engine - 93 Corvette LT1 ECM and wiring - 94 Z28 to start i have a 07 camaro v6 What hoov? Since when did LS1s come with 6 Cylinders? Quote Link to comment Share on other sites More sharing options...
hoov100 Posted August 31, 2009 Share Posted August 31, 2009 What hoov? Since when did LS1s come with 6 Cylinders? lol, thought he said 07. Quote Link to comment Share on other sites More sharing options...
OSearcy4 Posted August 31, 2009 Author Share Posted August 31, 2009 97s came with LT1. mine was a v6 though Quote Link to comment Share on other sites More sharing options...
OSearcy4 Posted August 31, 2009 Author Share Posted August 31, 2009 someone at another forum recommended this site. Quote Link to comment Share on other sites More sharing options...
ColtGT4g63 Posted August 31, 2009 Share Posted August 31, 2009 Take it back to the "place" that did the work, and ask 'em whats up? Quote Link to comment Share on other sites More sharing options...
OSearcy4 Posted August 31, 2009 Author Share Posted August 31, 2009 no offense man but i'm looking for real answers. not "buy a new car". i've already talked to the people who did the work and they dont want anything else to do with the car. Quote Link to comment Share on other sites More sharing options...
tfreer85 Posted August 31, 2009 Share Posted August 31, 2009 I'd say you need an ECM flash/tuner to make sure thats working correct. Figure out whats throwing your "check engine" code. The fans could be bad wiring to them causing the to "cut in and out." However that could also be resolved with the ECM and wiring check. I don't know of any good shops, but I know the feeling when the shop was supposed to do the work, did a crappy job. I'd take it to someone else, or send the ECM off to a tuner. Also check out the thirdgen forums and ls1tech, both have a lot of information on your exact swap. Good luck!! Quote Link to comment Share on other sites More sharing options...
ColtGT4g63 Posted August 31, 2009 Share Posted August 31, 2009 I don't understand how that was not a real answer?? But anyways... Maybe you should start with trying to figure out why you can't read the computer with a scanner. Whatever car the computer came from, look at the wiring diagram for that car and see how the communication wire is hooked up. If you've got it all wired up correctly and still can't communicate then I would start looking for a new computer. But make sure that whatever sensors / distributor / whatever you've got in there match what the computer you're going to pick up. Example: I would not buy a PCM for a 2004 Avalanche to replace the PCM for my 02 LS1. (Even though they're both gen3 motors and the PCM's look / have almost the same harness connector.) Quote Link to comment Share on other sites More sharing options...
OSearcy4 Posted September 1, 2009 Author Share Posted September 1, 2009 any recommendations for someone to reflash the pcm? i think that may be a good option. Quote Link to comment Share on other sites More sharing options...
