S30TRBO Posted September 7, 2009 Share Posted September 7, 2009 Does anyone have this and using SDS to control it? If so how did you wire it in? I have the white wire and relay from them but need to know what else I need. I also have the harness for the fan plug and it is cut behind the pig tail. I just emailed SDS for clarification to see if the EM4-6F can even control a multi-speed fan. Any help would be appreciated. Thanks, Quote Link to comment Share on other sites More sharing options...
dizzle Posted September 9, 2009 Share Posted September 9, 2009 I dont belive it will, are there two input wires? One for each speed? If so, you could run a standard thermesitor temp switch set to the lower temp and then have the sds output turn on at the higher temp. SDS is sweet for everyday reliablity but just doesnt have the bells and whistles that some stand alones do. But either way i love mine Quote Link to comment Share on other sites More sharing options...
S30TRBO Posted November 13, 2009 Author Share Posted November 13, 2009 I haven't tried this yet but here is an email from SDS: Only way to control both speeds I think would be to use the SDS RPM relay output, and say use it to turn on a low speed fan relay as shown in the hyridz diagram, and set the SDS to run low speed fan below about 1500 rpm (when idling and stopped in traffic) Then use the SDS fan relay output to activate hi speed fan. Rpm output is on the bottom row of white conn 3rd pin in from the db25 conn side. Connect this to pin86 of the low speed relay. White wire goes to 86 of the hi spd relay. I notice the hi speed relay overrides the low speed one so it should be safe. Quote Link to comment Share on other sites More sharing options...
Zreddy Posted November 19, 2009 Share Posted November 19, 2009 Summit sells these relays.... You can buy one for the low speed and the higher temp ones. Quote Link to comment Share on other sites More sharing options...
pallnet Posted December 24, 2009 Share Posted December 24, 2009 I know I'm kinda late here but if you have to run more then the low speed of a Taurus fan then you have a heat issue and the fan is the bandaid. You really should look into a 4 core radiator and venting the heat from the engine bay. A vented hood or vented inspection panels will help a lot. pallnet Quote Link to comment Share on other sites More sharing options...
