Rear A-Arm Design
The first ones are for my front, using an inner tie rod end for the rear pivot. The front rod end allows for bump steer tuning along with the custom tie rods
UMMMM those control arms are BADAZZ!!!!! are you thinking about selling them or just one set for your own car???
Wow, that's one hell of an expensive clevis!!! I think that is a useful item if you're using a custom circle track steering rack, but the most cost effective choice for this project.
I bought rectangular tube that had the correct ID for the rod end to slide in, drilled a hole, cut the tube at an angle, ground a little curve so that it fit the tube tightly and welded it to the arm. I think my clevises probably cost about $2 each, plus a little time on the grinder and drill press and welder.
