Livin9it2up1 Posted October 15, 2009 Share Posted October 15, 2009 today is the first time in a couple of days that i have driven my z. I noticed something extremely scary, when i let off the gas the rear end of the car pulls to the right. has anybody had a similar problem? my first guess was my bushings or my diff. Quote Link to comment Share on other sites More sharing options...
smokeybear Posted October 15, 2009 Share Posted October 15, 2009 It could be a frozen caliper too. Quote Link to comment Share on other sites More sharing options...
Livin9it2up1 Posted October 15, 2009 Author Share Posted October 15, 2009 It could be a frozen caliper too. Yeah ill try lifting the back of the car and see if theirs any resistance when i spin the wheel. Quote Link to comment Share on other sites More sharing options...
turboHLS30 Posted October 15, 2009 Share Posted October 15, 2009 Does it make any noise and how excatly does it pull????sorry if it sounds like a stupid question Quote Link to comment Share on other sites More sharing options...
big-phil Posted October 15, 2009 Share Posted October 15, 2009 before I replaced the bushings mine would wonder. In the rain it was real bad. New bushings fixed it for me! Quote Link to comment Share on other sites More sharing options...
Guest stdgrabbag Posted October 15, 2009 Share Posted October 15, 2009 i had a stuck caliper once, could be. Quote Link to comment Share on other sites More sharing options...
Livin9it2up1 Posted October 15, 2009 Author Share Posted October 15, 2009 Does it make any noise and how excatly does it pull????sorry if it sounds like a stupid question not a stupid question, just hard to answer.. it doesn't make any new noises, and when i let off the gas as in to coast, the car feels like I'm trying to get it sideways, i even have to counter steer a little bit to keep it straight. before I replaced the bushings mine would wonder. In the rain it was real bad. New bushings fixed it for me! Im leaning towards bushings, I really hope it is cause i wanted to replace them with poly ones anyways! Quote Link to comment Share on other sites More sharing options...
Livin9it2up1 Posted October 15, 2009 Author Share Posted October 15, 2009 i had a stuck caliper once, could be. would it pull the rear end to one side when you let off the gas? Quote Link to comment Share on other sites More sharing options...
rvannly Posted October 17, 2009 Share Posted October 17, 2009 What diff do you have? Long shot, but I remember one afternoon going home from willow springs. I had the same thing happen to me. I ran a 2 way lsd (240sx) and since it was after a drift event, I had miss matched tires in the rear. Well while driving home the car would want to veer to the right on accel but then do the opposite on decel(engine breaking) sure enough when I got home I replaced the rear wheels with matching ones and it drove normal. Quote Link to comment Share on other sites More sharing options...
z2go Posted October 17, 2009 Share Posted October 17, 2009 I second the caliper theory. It's easy and quick to check at least. Quote Link to comment Share on other sites More sharing options...
Livin9it2up1 Posted October 17, 2009 Author Share Posted October 17, 2009 What diff do you have? Long shot, but I remember one afternoon going home from willow springs. I had the same thing happen to me. I ran a 2 way lsd (240sx) and since it was after a drift event, I had miss matched tires in the rear. Well while driving home the car would want to veer to the right on accel but then do the opposite on decel(engine breaking) sure enough when I got home I replaced the rear wheels with matching ones and it drove normal. I have the stock 1975 280z diff as far as I know. I think its calld an r200. but I have matching wheels and tires in the rear. the first time it happened I thought I had a blowout so I pulled over in did the o'll tire kick but no flats so I got under the car and everything seemed fine. its starting to sound like sticking caliper is the culprate so I have time today to fix it. Quote Link to comment Share on other sites More sharing options...
Livin9it2up1 Posted October 17, 2009 Author Share Posted October 17, 2009 finaly got to mess with the z today, both driver and passenger side were good as far as brakes, all my bushings seemed to be intact with no play in between anything.. so i took it for a ride again.. nothings changed but i guess i left something out, When i get back on the gas it pulls in the opposite direction. any new ideas? Quote Link to comment Share on other sites More sharing options...
zedsn Posted October 18, 2009 Share Posted October 18, 2009 Is your Z pretty rusty underneath? If so maybe something is getting ready to go. Quote Link to comment Share on other sites More sharing options...
Livin9it2up1 Posted October 18, 2009 Author Share Posted October 18, 2009 Is your Z pretty rusty underneath? If so maybe something is getting ready to go. I don't like the sound of that! ill lift the car back up today and check everything again. Quote Link to comment Share on other sites More sharing options...
BunnySlippers Posted October 19, 2009 Share Posted October 19, 2009 Differential carrier bushings. Quote Link to comment Share on other sites More sharing options...
z2go Posted October 19, 2009 Share Posted October 19, 2009 Might be good time to change the rest of the bushings! Although, I said that at one point... and now I'm in the middle of a full resto-mod... Quote Link to comment Share on other sites More sharing options...
Livin9it2up1 Posted October 20, 2009 Author Share Posted October 20, 2009 Differential carrier bushings. Might be good time to change the rest of the bushings! Although, I said that at one point... and now I'm in the middle of a full resto-mod... Yeah i think im gonaa just replace all the busings Quote Link to comment Share on other sites More sharing options...
Livin9it2up1 Posted October 22, 2009 Author Share Posted October 22, 2009 ha found the problem, it was alot more obvious then i thought it was turns out the left rear control arm bushing was completely gone. I uploaded a video of the play in the control arm. Quote Link to comment Share on other sites More sharing options...
z2go Posted October 22, 2009 Share Posted October 22, 2009 Man, those things were TOAST. At least you know what you have to do. Good deal! Quote Link to comment Share on other sites More sharing options...
trwebb26 Posted October 22, 2009 Share Posted October 22, 2009 Jeez... glad you didn't get hurt. Quote Link to comment Share on other sites More sharing options...
