240zwannabe Posted November 10, 2009 Share Posted November 10, 2009 Ok, first off, I drive an sr20 240sx with a kaaz 2-way as a daily driver. My question was, should the differential make sort of a chattering/popping noise that i can also feel while driving in areas where low acceleration and carefulness are required (parking lots, etc..)? Thanks in advance. edit: I searched but only came up with results concerning fitment in r200's. Quote Link to comment Share on other sites More sharing options...
deja Posted November 10, 2009 Share Posted November 10, 2009 Try some friction modifier. My R200 LSD did that too until I added the modifier, I got mine from a GM dealer but there are many options. Its a small bottle so there's no need to remove any diff fluid. Quote Link to comment Share on other sites More sharing options...
240zwannabe Posted November 10, 2009 Author Share Posted November 10, 2009 Try some friction modifier. My R200 LSD did that too until I added the modifier, I got mine from a GM dealer but there are many options. Its a small bottle so there's no need to remove any diff fluid. Is that something i can buy at a local auto parts store? Quote Link to comment Share on other sites More sharing options...
deja Posted November 10, 2009 Share Posted November 10, 2009 Probably, Redline makes it. http://www.redlineoil.com/dealers.aspx But its cheap at your local Chevy dealer too. Quote Link to comment Share on other sites More sharing options...
JMortensen Posted November 10, 2009 Share Posted November 10, 2009 Any parts store will have it. Some say GM, some Chrysler, some Ford. It's all the same stuff. If you add one bottle/container/tube and it still chatters, add another. Just keep adding until the noise goes away, you won't hurt anything. Quote Link to comment Share on other sites More sharing options...
240zwannabe Posted November 10, 2009 Author Share Posted November 10, 2009 cool, thanks guys. Quote Link to comment Share on other sites More sharing options...
280zjoel Posted November 10, 2009 Share Posted November 10, 2009 Ok, first off, I drive an sr20 240sx with a kaaz 2-way as a daily driver. My question was, should the differential make sort of a chattering/popping noise that i can also feel while driving in areas where low acceleration and carefulness are required (parking lots, etc..)? Thanks in advance. edit: I searched but only came up with results concerning fitment in r200's. Is it the tires you hear making noise? since you have a 2 way its engaged on acceleration and deceleration, so you should hear the inside rear tire(of the direction your turning) slipping at low speeds since it wants to move at the same pace as the outside tire. Just a thought. Quote Link to comment Share on other sites More sharing options...
240zwannabe Posted November 10, 2009 Author Share Posted November 10, 2009 Is it the tires you hear making noise? since you have a 2 way its engaged on acceleration and deceleration, so you should hear the inside rear tire(of the direction your turning) slipping at low speeds since it wants to move at the same pace as the outside tire. Just a thought. No, if it was the tires making noise, I would've said that. Not trying to be a jerk, but sometimes I come off as one. It's a popping noise when I'm trying to keep low acceleration and take turns. Quote Link to comment Share on other sites More sharing options...
240zwannabe Posted November 11, 2009 Author Share Posted November 11, 2009 Is "tran-x" a friction modifier? I went to 3 different auto parts stores and I finally found that stuff. On the label it said it stops chatter and noises from limited slip diferentials. Quote Link to comment Share on other sites More sharing options...
JMortensen Posted November 11, 2009 Share Posted November 11, 2009 Sounds like it. Quote Link to comment Share on other sites More sharing options...
240zwannabe Posted November 11, 2009 Author Share Posted November 11, 2009 Sounds like it. It's a 7 fl. oz. tube is that the same size you all used/experienced? Quote Link to comment Share on other sites More sharing options...
deja Posted November 11, 2009 Share Posted November 11, 2009 Yep. It's a 7 fl. oz. tube is that the same size you all used/experienced? Quote Link to comment Share on other sites More sharing options...
