Mirawho Posted November 23, 2009 Share Posted November 23, 2009 I saw this problem posted before and don't remember seeing a resolution for it. Now I am having this same problem. Here is the current problem: Just replaced all injectors as some were bad (Z was running prior to installation) Pump starts 12v on both sides of FI connector ECU replaced 6 Ohms on all terminals on resistor Any suggestions? Oh, 81ZX non-turbo. There is spark and if you touch the injector to ground, it sprays, so it looks like it is not getting the ground from the ECU, but we just replaced the ECU. Quote Link to comment Share on other sites More sharing options...
chrism Posted November 23, 2009 Share Posted November 23, 2009 Is the ECU grounded properly? I think you are right that there is a ground issue. Try using a noid light . Place it across the contacts of the injector plug. You should see the light blink if the ECU is providing a good ground pulse when turning over the engine. If you don't have one then you can use a multimeter to see if the voltage is dropping when the motor turns over. A ground pulse from the ECU should pull the voltage down a couple of voltes. Quote Link to comment Share on other sites More sharing options...
Mirawho Posted November 24, 2009 Author Share Posted November 24, 2009 So, I disconnected the connector on the MAF and reconnected it and it fired right up. Now it starts up every time. Hmmm........ time to replace the MAF too. Quote Link to comment Share on other sites More sharing options...
s!lvias30 Posted November 24, 2009 Share Posted November 24, 2009 ok some one please tell me how many volts is each connector to the injector suppose to have??? i need a DIY for checking exactly if im getting any power in my wire harness, because im not getting any fuel !!! i have a fuel pressure gauge and it is reading 40psi and thats enough , i dont know what are the next steps i should take in order to find out whats going on ..... if there is any one near orlando florida that can help please pm me !! im going crazzy ...... what can my problem be ??? 1. got fuel 40psi 2 .fuel pump works good, on a switch straight to the battery 3.battery have 13volts 4.new fuel filter 5. no gunk in the fuel lines , i check really good 6.new fuel injection main relay 7. new wiring harness 8 new ecu, and 2 extra ones also 9.new sprk plugs, wires , and checked timing 10. new maf aka efi, with 2 extra ones 11. new blaster 12. no vacum leak 13. check for spark and its coming out blue and a little yellow 14. i dont hear the injectors clicking at all 15. checked and took off each injector and cleaned them and used wires and a 12volt battery and then heard them click and i put gas in them and they where squrting. honestly i have done alot , i have a feeling im not getting any fuel because im not hearing the injectors click , also how do i check if im getting power to my harness and power to my ecu , when should i be able to here the injectors click??? , please i need step by step actions that i need to take in order to fix my problem , thanks you can text me for quicker response or email , 321 3560874 zunigasamuel8@gmail.com Quote Link to comment Share on other sites More sharing options...
s!lvias30 Posted November 24, 2009 Share Posted November 24, 2009 sorry i am having the same issues but its not the maf Quote Link to comment Share on other sites More sharing options...
Administrators BRAAP Posted November 25, 2009 Administrators Share Posted November 25, 2009 sorry i am having the same issues but its not the maf maf? What maf? Show me an '81 zx with a factory installed MAF! Quote Link to comment Share on other sites More sharing options...
Tony D Posted November 26, 2009 Share Posted November 26, 2009 Looks like a crosspost to me! And BRAAP, you missed it! Baaad Moderator, Baaaad Moderator! Quote Link to comment Share on other sites More sharing options...
