team_infidel Posted November 30, 2009 Share Posted November 30, 2009 Hey guys, was wondering if it is possible to put an N 42 head off of a 75 280z onto a L 24 block in a 72 240z. what problems will i run into, and will it make any power, or just remain the same basically. Please keep it simple, i am in the army for a reason Quote Link to comment Share on other sites More sharing options...
BluDestiny Posted December 1, 2009 Share Posted December 1, 2009 Most heads are interchangeable between the blocks although some say you might need some slight modifications. I personally have only delt with putting head on the F54 (L28) block, and they all work. depending on what head you already have on(it should be a E88, but could be another if the engine was replaced at one time) and you put on the N42, the biggest difference will be the larger valves. If you're going to replace the head, why don't you just drop in the whole L28? Quote Link to comment Share on other sites More sharing options...
510six Posted December 2, 2009 Share Posted December 2, 2009 You will have to "eyebrow" the 240 block to clear the larger valves in the N42 head. Quote Link to comment Share on other sites More sharing options...
Tony D Posted December 2, 2009 Share Posted December 2, 2009 Yes, you might have to eyebrow the smaller bore in the L24 block. A 260Z block had these 'eyebrows' in it already as they moved to larger valves in those heads. It all depends on your head and how it lines up, some won't hit, others do. Mine did, but didn't bend a valve and only put maybe a 0.020" nick in the block where the valve went by...and then only on three cylinders. A quick clearance with a die drinder with some grease to protect the top of the piston and rings from swarf falling in during the process, and you don't even need to pull the engine apart to do that! Quote Link to comment Share on other sites More sharing options...
ozconnection Posted December 4, 2009 Share Posted December 4, 2009 A quick clearance with a die drinder with some grease to protect the top of the piston and rings from swarf falling in during the process, and you don't even need to pull the engine apart to do that! At some point in this process, you have to turn the crank to drop the 'other' pistons down their bores for grinding........good luck with the timing chain! Quote Link to comment Share on other sites More sharing options...
Noddle Posted December 4, 2009 Share Posted December 4, 2009 Yes, you might have to eyebrow the smaller bore in the L24 block. A 260Z block had these 'eyebrows' in it already as they moved to larger valves in those heads. It all depends on your head and how it lines up, some won't hit, others do. Mine did, but didn't bend a valve and only put maybe a 0.020" nick in the block where the valve went by...and then only on three cylinders. A quick clearance with a die drinder with some grease to protect the top of the piston and rings from swarf falling in during the process, and you don't even need to pull the engine apart to do that! This is what mine looks like, looks like the valves 'self cleared' Nigel Quote Link to comment Share on other sites More sharing options...
dhunt571 Posted December 23, 2009 Share Posted December 23, 2009 will you have to clearance or "Eye beow" an f54 block if you put an N-42 head on it? I have an f-54 with flat tops that origionally came with a p-79. Will the valves hit the sides??? -dan Quote Link to comment Share on other sites More sharing options...
ozconnection Posted December 23, 2009 Share Posted December 23, 2009 will you have to clearance or "Eye beow" an f54 block if you put an N-42 head on it? I have an f-54 with flat tops that origionally came with a p-79. Will the valves hit the sides??? -dan L28 block and head. No. (so long as there isn't any radically oversized valves in that N42). Quote Link to comment Share on other sites More sharing options...
f1race79 Posted February 23, 2011 Share Posted February 23, 2011 Is this for the exhaust, intake or both? Thanks, Julius Quote Link to comment Share on other sites More sharing options...
