coilover spring rates
The Illuminas rebound valving is limited to spring rates of 275 lb. in. or less. Ideally you need to say under 250 to be able to use some of the adjustability in the shock.
John, so what you're saying is that with a stiffer spring, such as 250 lb/in, the illuminas can only be used on their higher settings, say 4 and 5?
Yes. But I say that in the context of autocross and track use. On the street you can run lower the lower adjustment numbers but the spring won't be as controlled.
