Zgotrip Posted December 18, 2009 Author Share Posted December 18, 2009 Andy...I did not do any of the mods on this car this is just the way she came to me, so as far as why the springs sit where they do its just a result of the sum of the parts i guess..as far as suspension travel i can let you know when the car is off the stands. Pictures? I have a few... Quote Link to comment Share on other sites More sharing options...
Zgotrip Posted December 18, 2009 Author Share Posted December 18, 2009 Quote Link to comment Share on other sites More sharing options...
Xylemer Posted December 18, 2009 Share Posted December 18, 2009 I had a thought, maybe someone could chime in and correct me if I am wrong. I know some people use 8" springs on the front, would this help with the rubbing? Less spring would equal less deflection, which then would decrease the chance for rubbing. Are there any disadvantages to using a smaller spring of the same weight? Quote Link to comment Share on other sites More sharing options...
johnc Posted December 18, 2009 Share Posted December 18, 2009 Are there any disadvantages to using a smaller spring of the same weight? Coil bind. An 8" spring needs to be over 250 lb. in. to keep from coil binding in a typical S30 application. Quote Link to comment Share on other sites More sharing options...
EvilC Posted April 5, 2010 Share Posted April 5, 2010 Spoke to GC today and they agree with the camber plate tops would help the issue. Also another "fix" is running shorter collars. Do you susp experts agree with that? I am thinking I am never going to use the top four inches or so of the collar so do I really need it there? GC will sell you collars in whatever length you want. They normally ship with 6 inch collars...so I got them. If it is a good idea to cut them down some then I will. Again, the shearing of the top of the collars do not damage the car or handling at all. Quote Link to comment Share on other sites More sharing options...
