Delasangre4231 Posted January 24, 2010 Share Posted January 24, 2010 Is there a gasket that goes between the bellhousing and the block? Quote Link to comment Share on other sites More sharing options...
FlatBlack Posted January 24, 2010 Share Posted January 24, 2010 No Quote Link to comment Share on other sites More sharing options...
Delasangre4231 Posted January 24, 2010 Author Share Posted January 24, 2010 Alright, sounds good. Anything else I should be worried about when changing the trans? I got the clutch, clutch slave, clutch hose, new starter, new fluid, new shift knob, resurfaced flywheel and alot of time... Quote Link to comment Share on other sites More sharing options...
Mayolives Posted January 24, 2010 Share Posted January 24, 2010 QUOTE: "I got the clutch, clutch slave, clutch hose, new starter, new fluid, new shift knob, resurfaced flywheel and alot of time... Now would be a good time to replace the T/O bearing and the pilot shaft bushing. Quote Link to comment Share on other sites More sharing options...
Delasangre4231 Posted January 24, 2010 Author Share Posted January 24, 2010 That comes in the clutch kit. Quote Link to comment Share on other sites More sharing options...
roger.svoboda Posted January 24, 2010 Share Posted January 24, 2010 clutch hard line from master to slave. console cover. pedal assembly. Might as well change the pilot bushing cheap and you are right there. Make sure the clutch fork fulcrum pin is sound but for $6 I'd just put in a new one. Might as well do the tranny input shaft bearing another failure spot often. You need to bypass the auto tranny interlocks to start it. If not new get them master and slave cylinder. Tranny jack is a good thing to have. Rent someplace or buy at harbor freight $50 if I remember. Three 12" extensions for your socket set to reach the bolts from under the car. Quote Link to comment Share on other sites More sharing options...
Nissanxrma Posted January 29, 2010 Share Posted January 29, 2010 Change out the pivot ball. They're prone to failiure. Quote Link to comment Share on other sites More sharing options...
roger.svoboda Posted January 29, 2010 Share Posted January 29, 2010 that is called the clutch fork fulcrum pin if you want to buy one Quote Link to comment Share on other sites More sharing options...
