Another Starting Issue, no spark *pics*
Daphur280
  • Replies 47
Did you ever check if your switched power stays alive during crank? Also was this an entire swap and running when removed? Also
Do you have the white connector in this pic http://i128.photobucket.com/albums/p185/phantomstarr/L28et%20into%20S30/DSC00161.jpg hooked up like so?
-Green - Constant power (Needs to be run to a 12+ volt constant)
-Black with white strip - Switched power (Needs to be run to a 12+ volt switched power) The end from the relay side needs to goto the switched power. Not the harness side.
Edited by loy
that white connector isn't hooked up to anything, is it suppose to be connected?
switched power stays connected through cranking as long as starter solenoid is disconnected, however, switched power I believe goes out when starter is connected. The ECU light stays on through cranking so long as the starter isn't hooked up, and stays on up until cranking when the starter is engaged and connected.
Yes. Should be figure N on the l28et swap guide/Plug 3 on the 82/83 supplement pic. Do you have a multimeter?
Edited by loy
How are you cranking if the starter is disconnected? The ECU needs to have power while cranking or the car won't start. No ECU power while cranking means no fuel or spark while cranking so the engine will never start.
Joe
When i meant cranking, I meant i had the ignition switch to the "START" position and the ecu light would be on when the starter was disconnected, but when the starter was connected and I would crank the enginge, the ecu light would go out during cranking...
sorry about the confusion
Okay, so that must be fixed first. You need to find a source that doesn't turn off the ECU while cranking. I'm not familiar with the doc you guys are talking about but it sounds like you are not using the same source as people who have who have running swaps are. Unfortunately, I can't check the source on my car since it is in winter hibernation which is about 20 miles away.
Joe
ok so I looked back at the diagram, and yes I did miss this one, So I hooked up everything accordingly on Fig N, and when cranking the ECU light still goes out, and now the fuel pump wont turn off.
As another note, I dont know if anyone read towards the beginning of this thread, but because I DID NOT have the harness that plugs the FUEL PUMP RELAY harness to the FI harness, I wired up the FUEL PUMP RELAY seperate from EFI harness. before this whole issue arrised I tested that the FUEL PUMP RELAY and fuel pump were both working properly so I do not suspect its within the way this was wired
However
I know that the harness that plugs into the FUEL PUMP RELAY harness did supply power to the ECU... which I already wired up to the 8pin connector...
oh yeah, still no spark... :angry:
Edited by Daphur280
So how about my unanswered questions? Do you have a multimeter? Also was this an entire swap and running when removed? Led will go off while cranking. What did you change to your fuel pump wiring? The only wire on that harness was blue/red, And it's the signal for the relay.
Edited by loy
Sorry, the answer is no, I do not have one, it was very foolish of me to get heavily involved in the automotive field without investing in one. Simple fact for me is I'm not good at using one, so I've tended to avoid it.
All I have is a test light and that has sufficed thus far.
I dont have the cash to get one, because I'm saving what i do have to pay someone to fix this or for parts (if that becomes the issue).
Also, thank you for answering the question/concern about the LED on the ECU while cranking, wasn't sure what was suppose to happen with that during cranking.
The only thing I changed about the FUEL PUMP RELAY was, I connected the connectors directly to their source: Fuel pump (+); Ground, 12v constant; 12v switched (IGN ON). None of what I connected to the relay is going to the EFI harness or ECU.
the blue/red wire i have isn't connected to anything on the end of the connector (by the EFI relay) But i do have the blue/red wire connected to IGN ON on the harness side (by the ECU connectors)
I will upload pics of this later tonight to limit confusion about my setup...
Edited by Daphur280
I suspect you are missing more than just spark. With all of the attempted starting you are doing, if the injectors were indeed firing, the spark plugs should be full of unburned gas. Is that the case? If not, I'm still leaning to the ECU being "off" while cranking.
Joe
It's not hard to relearn. Anyways, if you are sure that everything is connected correctly then it might be time to start looking at components. Check that your distributor is sending a signal to ecu and what not.
Here's an ecu pinout diagram. http://forums.hybridz.org/index.php?/topic/51518-look-what-i-found-83-280zxt-wiring-diagram-with-ecu-pinout/page__view__findpost__p__456420
Here's a multimeter how to http://mechatronics.mech.northwestern.edu/design_ref/tools/multimeter.html
See post 31.
Edited by loy
