crazyoctopus Posted February 22, 2010 Share Posted February 22, 2010 As far as I can tell the only way for me to get some SS lines from the 240sx rear brake caliper to my stock (73 240z) hard lines is by purchasing a $75 pair from MM. Is there another option? It seems kinda insane to think that the full 240z SS kit from thezstore is pretty much the same price; and that is for 4 lines, not just 2. i know that there is a rubber option to be found at rock auto, but as the title says i am looking for an SS option. Quote Link to comment Share on other sites More sharing options...
crazyoctopus Posted February 22, 2010 Author Share Posted February 22, 2010 alright with the new search software i was able to find some info on what i needed, but this arouse another question... Right now i have the MSA SS lines all around; obviously this will not work with the 240sx rear caliper, but i figure that i could just get a 10mm banjo adapter to the male threaded end then I would not have to buy the expensive pair of SS lines. I have e-mailed MSA asking them what the thread pitch is, but if anyone knows off hand that would be great. the brake would be set up as such... caliper > banjo adapter > MSA SS lines > hard lines. Quote Link to comment Share on other sites More sharing options...
junglist Posted February 22, 2010 Share Posted February 22, 2010 On The Outlaw Brakes site there is some info and pics on what he does to adapt the rear 240SX brake lines. http://www.outlawbrakes.com/brakes.html I don't know if he still sells brake stuff. Quote Link to comment Share on other sites More sharing options...
crazyoctopus Posted February 22, 2010 Author Share Posted February 22, 2010 from the looks of that set-up is is a 10mm banjo ss hose with a 3an end, and then a 3an to 10mm adapter. Granted it is $15 cheaper than MM, but still i already have ss lines i just need an adapter... Quote Link to comment Share on other sites More sharing options...
crazyoctopus Posted February 22, 2010 Author Share Posted February 22, 2010 (edited) alrighty so i think i figured it out. since i already have the banjo bolts on the caliper these are the parts that you need to buy for your stock brake line to work, and subsequently the SS kit that MSA sells. you will need to buy --pair of banjo fittings; fitting size 1: -3an fitting size 2: 10mm banjo link http://www.summitrac...rts/RUS-640471/ --pair of male to male fittings fitting size 1: -3an fitting size 2: 10mm x 1.0 INVERTED FLARE link http://www.summitrac...rts/FRA-650307/ --pair of female to female couplers fitting size 1: -3an fitting size 2: -3an link http://www.summitrac.../EAR-915103ERL/ total cost being $37.18 to recap -option 1 (4) MSA SS lines - $80 (2) MM SS lines - $75 total cost $155 -Pro, you have ss lines that bolt right up -Cons, you have to throw away/sell the rears that you get from MSA also since you cant actually buy the SS lines by themselves shipping will cost you an extra $30; being that you have to use buy a kit and remove what you dont need so total cost is now $185 option 2 (4) MSA SS lines - $80 couplers and fittings - $40 total cost $120 -Pro, dont have to throw anything away, and less expensive -cons, semi-jerry rigged look. As always it is up to the buyer, but saving an extra $35-$65 is quite a bit, after all that is pretty much the cost of new pads (Porterfield R4-S = $60) Edited February 22, 2010 by crazyoctopus Quote Link to comment Share on other sites More sharing options...
silverarrow27 Posted February 25, 2010 Share Posted February 25, 2010 Very great post. I've been thinking about finding a solution to this myself because I have all four ss brake lines already too. Quote Link to comment Share on other sites More sharing options...
crazyoctopus Posted February 25, 2010 Author Share Posted February 25, 2010 once i get all of the material to the house i'll post some photos up and add them to the rear brake FAQ so that way people can see what it looks like. I also got back from MM about the extra shipping cost, and they would lower it after i made the purchase and refund the money; still though you save $30 and dont have an extra set of SS lines that you have to dispose of. Quote Link to comment Share on other sites More sharing options...
crazyoctopus Posted February 28, 2010 Author Share Posted February 28, 2010 I got all of the parts in and here are the photos. here is what the stock attachment looks like I went with a different banjo adapter than i originally said, and probably should have stuck with it. with this setup i will probably have to grind off one of the tabs. the stainless lines are from MSA; 10mm x 1.0 inverted nipples on both ends. Quote Link to comment Share on other sites More sharing options...
bjhines Posted February 28, 2010 Share Posted February 28, 2010 I ordered custom braided stainless lines from Pegasus Racing Supplies for ~$16 each line.. Banjo to metric flare. I would not use that stack of fittings on the wheel end of my brake system. That is just wrong on sooooooo many levels. Quote Link to comment Share on other sites More sharing options...
crazyoctopus Posted February 28, 2010 Author Share Posted February 28, 2010 ... where was this when i was asking for info... Quote Link to comment Share on other sites More sharing options...
bjhines Posted February 28, 2010 Share Posted February 28, 2010 I don't know what to tell ya. You can assume that most retailers are getting 200% mark-up on kitted parts. They charge for their knowledge. They usually source good stuff too. MM makes a fantastic kit even if it is a little more expensive. There are a few suppliers I have seen that will attach any configuration you like with die-crimped fittings. You will have to hunt for that, I don't have anyone right off the bat. My gettin-spot for a lot of stuff is Pegasus Racing Supplies. They only offer AN-3 to 3/8" banjo. http://www.pegasusautoracing.com/bigpicture.asp?RecID=755 so you would need the wheel end adaptor that attaches directly to the chassis brake line clip/holder. http://www.pegasusautoracing.com/productdetails.asp?RecID=4205 That way there is no extra weight or fittings on the wheel end. Quote Link to comment Share on other sites More sharing options...
zcarnut Posted March 1, 2010 Share Posted March 1, 2010 I made my own with Earl’s Performance fittings. Cost per side came to $22.36. Quote Link to comment Share on other sites More sharing options...
crazyoctopus Posted March 11, 2010 Author Share Posted March 11, 2010 noticed my rear brake reservoir fluid a bit lower so i filled it up, and pumped teh brakes to see if the level went down... it did. so i looked around to see if there was any leakage on any of the brakes. this is what i found. looks like i am going with a different route. Quote Link to comment Share on other sites More sharing options...
crazyoctopus Posted March 12, 2010 Author Share Posted March 12, 2010 zcarnut - I was looking at the routing that the 6" of line would take, it seems kinda tight. is it going to be long enough to maintain proper droop, and not snap off when at maximum travel? Quote Link to comment Share on other sites More sharing options...
bjhines Posted March 12, 2010 Share Posted March 12, 2010 6" seems like less than half what you need. Many folks have replaced and relocated the hardlines so you need to measure yourself. Find something that flexes similarly to braided hose and check routing at full compression and full droop. I seem to remember 16" for the rears. Quote Link to comment Share on other sites More sharing options...
PHANTOM-POWER Posted March 12, 2010 Share Posted March 12, 2010 Dont know if this helps but there is a guy on Ebay selling lines for the 86 NISSAN MAXIMA CALIPERS and 1982 NISSAN 280ZX REAR BRAKE ROTOR set up. for $45.00 a set Its worth checking out to see if they will work on the 240sx setup. http://cgi.ebay.com/ebaymotors/Datsun-240Z-260Z-280Z-Rear-Disc-Conversion-Brake-Lines_W0QQitemZ260558423031QQcmdZViewItemQQptZMotors_Car_Truck_Parts_Accessories?hash=item3caa7e03f7 Don't mean to hijack your thread but does anyone know if I can use these same lines for the front 4x4 vented toyota setup on a 240z. Thanks Ahmed Quote Link to comment Share on other sites More sharing options...
crazyoctopus Posted March 12, 2010 Author Share Posted March 12, 2010 Any downside to running ss from the T all the way to the caliper? Quote Link to comment Share on other sites More sharing options...
bjhines Posted March 13, 2010 Share Posted March 13, 2010 (edited) Disadvantage is; more flexible hose means squishier pedal. The flex lines should only be a long as needed for suspension travel and full droop when the car is lifted. Do you need new hardlines? If so, then check out autozone for nice brake line tubing, pre flared with metric fittings in a variety of lengths. To sum up your problems; 1. You used MSA factory replacement lines. They have tube-flare fittings on both ends because that is what the factory hoses went to. 2. You spent almost as much on adaptors and shipping as new lines would have cost you. 3. adaptors failed, that is the learning curve working there. Folks with experience would have known better. You have to learn somehow. 4. You are still ignoring what folks have told you by "re-engineering" your hardlines. You need: 2x ~16" hoses with AN-3 and 3/8"-Banjo ($18 each) 2x Chassis braket adaptors with Metric tube flare to AN-3 ($3 each) ... Edited March 13, 2010 by bjhines Quote Link to comment Share on other sites More sharing options...
mclark999 Posted November 16, 2011 Share Posted November 16, 2011 Disadvantage is; more flexible hose means squishier pedal. The flex lines should only be a long as needed for suspension travel and full droop when the car is lifted. Do you need new hardlines? If so, then check out autozone for nice brake line tubing, pre flared with metric fittings in a variety of lengths. To sum up your problems; 1. You used MSA factory replacement lines. They have tube-flare fittings on both ends because that is what the factory hoses went to. 2. You spent almost as much on adaptors and shipping as new lines would have cost you. 3. adaptors failed, that is the learning curve working there. Folks with experience would have known better. You have to learn somehow. 4. You are still ignoring what folks have told you by "re-engineering" your hardlines. You need: 2x ~16" hoses with AN-3 and 3/8"-Banjo ($18 each) 2x Chassis braket adaptors with Metric tube flare to AN-3 ($3 each) ... I bought some SS lines that have the right fittings on each end, but they are only about 12" long. With the rear tires off, I can raise the suspension high enough that they bind at the top of the range. I would buy some from Ross at Modern Motorsports, but he doesn't seem to be around anymore. Anyone know where I can get longer ones? Quote Link to comment Share on other sites More sharing options...
bjhines Posted November 17, 2011 Share Posted November 17, 2011 Pegasus Auto Racing Supplies. Quote Link to comment Share on other sites More sharing options...
