yetterben Posted April 9, 2010 Share Posted April 9, 2010 My gas tank is leaking from the sending unit poles where the wires go. Anyone seen this before. Quote Link to comment Share on other sites More sharing options...
theghosttanker Posted April 10, 2010 Share Posted April 10, 2010 I haven't seen it before, but i have a non-leaking sending unit around here somewhere that I'll sell ya if i can find it. Quote Link to comment Share on other sites More sharing options...
zgeezer Posted April 12, 2010 Share Posted April 12, 2010 My gas tank is leaking from the sending unit poles where the wires go. Anyone seen this before. Are you sure it's not the "O" ring , which seals the sending unit to the gas tank, that's leaking? "O" rings are easy to find and replace; the sending unit can be a pricey item. G Quote Link to comment Share on other sites More sharing options...
yetterben Posted April 12, 2010 Author Share Posted April 12, 2010 it was the + lead pole around the base. new sending unit secured for 38 bucks. Quote Link to comment Share on other sites More sharing options...
lowrider Posted April 12, 2010 Share Posted April 12, 2010 I had a problem with mine leaking there a while back. I ended up removing it from the tank and pinching the post from the inside and the out with a pair of vice grips to get it tight against the seal again. Worked like a charm and has'nt leaked since. Quote Link to comment Share on other sites More sharing options...
