ghostu2 Posted April 21, 2010 Share Posted April 21, 2010 (edited) Hi guys I'm putting a rb20det into a 260Z. The chassis has custom coilovers, tokico 5way adjustable illuminas, new polyurethane, adjustable tie rods and toe links, strut tower bar front and rear 275rears and 255 fronts.I wanted some people to chime in on if the RBs make the car more nose heavy with understeer more than a L28ET would. I expect some type of difference but with mods listed will car still handle nicely? Edited April 23, 2010 by ghostu2 Quote Link to comment Share on other sites More sharing options...
johnc Posted April 21, 2010 Share Posted April 21, 2010 Hi guys I'm putting a rb20det into a 260Z. The chassis has custom coilovers, tokico 5way adjustable illuminas, new polyurethane, adjustable tie rods and toe links, strut tower bar front and rear 275rears and 255 fronts.I wanted a some people to chime in on if the RBs make the far more nose heavy with understeer more than a L28ET would. I expect some type of difference but with mods listed will car still handle nicely? What spring rates? What size anti-roll bars? What brand and model tire? What size rims? How much does the car weight? Any corner weight numbers? What are your alignment numbers? Quote Link to comment Share on other sites More sharing options...
ghostu2 Posted April 22, 2010 Author Share Posted April 22, 2010 What spring rates? What size anti-roll bars? What brand and model tire? What size rims? How much does the car weight? Any corner weight numbers? What are your alignment numbers? Spring Rate = 200ILBs Anti Roll Bars=1" or more? Tires= Hankook Ventus HR II Rim= 17x9 up front 17x9.5 back Rota RBs Car Weight=Average 260Z weight ? dont have car scale No Corner Weights No Alignment #s Didn't realize it took so much to get a general Idea. If Corner Weighting will help and certain alignment #s for having a RB in your chassis will I am interested. But generally a seat of the pants feel from members who actually have and drive their RBZs daily. Quote Link to comment Share on other sites More sharing options...
Canadianz Posted April 23, 2010 Share Posted April 23, 2010 Spring Rate = 200ILBs Anti Roll Bars=1" or more? Tires= Hankook Ventus HR II Rim= 17x9 up front 17x9.5 back Rota RBs Car Weight=Average 260Z weight ? dont have car scale No Corner Weights No Alignment #s Didn't realize it took so much to get a general Idea. If Corner Weighting will help and certain alignment #s for having a RB in your chassis will I am interested. But generally a seat of the pants feel from members who actually have and drive their RBZs daily. They handle fine, even on my old beat up chassis with just lowering springs. I think you will have a ton of fun with it I wouldn't worry. Quote Link to comment Share on other sites More sharing options...
RB26powered74zcar Posted April 23, 2010 Share Posted April 23, 2010 I can't see a RB20 adding that much more, if any, compared to putting a 280zxt L6 in a s30. I have the 26 in my 260z with twins, and lots of extra added weight vs stock L6, and my car handles fine to me. I'm not qualified to speak on what it would do as a track car though, compared to the L6. Street wise, it feels orgasmic.... Quote Link to comment Share on other sites More sharing options...
ghostu2 Posted April 23, 2010 Author Share Posted April 23, 2010 Coolio. Sounds like I should be fine,......staying the course on her then. ;-/ Quote Link to comment Share on other sites More sharing options...
johnc Posted April 23, 2010 Share Posted April 23, 2010 Didn't realize it took so much to get a general Idea. Yes it does. If you just gloss over the important stuff (like alignment) you'll never really know how well these cars can handle. Quote Link to comment Share on other sites More sharing options...
2eighTZ4me Posted April 23, 2010 Share Posted April 23, 2010 Nor can you do corner balancing without an adjustable coilover setup. (johnc - correct me if I'm wrong) Quote Link to comment Share on other sites More sharing options...
z-ya Posted April 23, 2010 Share Posted April 23, 2010 Engine placement is going to effect the handling (weight balance) as well. Ive seen some mounted high and forward, and others (like mine), mounted close to the firewall and low. So it really depends on a lot of things. Nor can you do corner balancing without an adjustable coilover setup. (johnc - correct me if I'm wrong) You need scales, and at a minimum adjustable coil overs. Quote Link to comment Share on other sites More sharing options...
johnc Posted April 23, 2010 Share Posted April 23, 2010 Nor can you do corner balancing without an adjustable coilover setup. (johnc - correct me if I'm wrong) You can do corner balancing without threaded collars. You just have to move stuff around in the car (battery, etc.), put spacers under or on top of the springs, and other stuff. Its just a helluva lot easier with threaded collars. Quote Link to comment Share on other sites More sharing options...
johnc Posted April 23, 2010 Share Posted April 23, 2010 You don't have to have coil overs or do corner balancing to get a good handling S30. You do have to do that stuff to get a great handing S30. Quote Link to comment Share on other sites More sharing options...
NZeder Posted April 26, 2010 Share Posted April 26, 2010 (edited) The RB vs L28 would be 30KG more approx and that would be without turbo's so with turbo, air con pumps etc more KG (or LB for those state side that still use imperial ) so as other have stated location location location. Remember Nissan made the Z432 which had an engine that was the weight o the RB anyhow (the S20) so the chassis is up to the weight stock for stock ie RB20DE or RB25DE, RB30 would be heavier as the block is bigger. The point it should not upset the stock handling, however as other have already stated if you want the S30 chassis to handle great, some tweaks are required via adjustable suspension. Edited April 26, 2010 by NZeder Quote Link to comment Share on other sites More sharing options...
Bishopsrock Posted April 26, 2010 Share Posted April 26, 2010 (edited) Out of personal interest - is there any consensus as to what the optimum settings for Tokiko Illuminas should be for an RB26 240z - front and rear??? Edited April 26, 2010 by Bishopsrock Quote Link to comment Share on other sites More sharing options...
johnc Posted April 26, 2010 Share Posted April 26, 2010 Out of personal interest - is there any consensus as to what the optimum settings for Tokiko Illuminas should be for an RB26 240z - front and rear??? Shocks are adjusted based on spring rate. What springs are on your car and what rate are they? Quote Link to comment Share on other sites More sharing options...
Bishopsrock Posted April 26, 2010 Share Posted April 26, 2010 Shocks are adjusted based on spring rate. What springs are on your car and what rate are they? Hi John, My pride & joy is a stock 73 model US car that I imported from California and that was manufactured during Nov 72. Thanks Quote Link to comment Share on other sites More sharing options...
Wedge Posted May 1, 2010 Share Posted May 1, 2010 I talked to a local Z guy freak about my RB26 (around 300 hp)swap and besides what you guys are talking about he told me i should spot weld my shock towers and other places in the engine bay to prevent it from cracking I was wondering what you guys think about that ? Quote Link to comment Share on other sites More sharing options...
