l28et flywheel question.
mldub2
I am going from auto to manual tranny. Here is my question. When i took of the flex plate it has 2 plates on both sides of it. when i try to install the flywheel with the 2 plates the bolts are short. Are the plates only for the flexplate because its thiner or are manual tranny blots longer.
Just put in on with out the plates and it looks good. Thank you so much for your help.
You got it right - the plates are not for the flywheel.
I've seen the outer plate used as a washer to keep the bolts from deforming an aluminum flywheel, but that doesn't leave very many threads for the bolts to engage the crankshaft.
The automatic transmission has a flex plate with a washer/spacer sandwiched between the engine block and the flex plate..
In order to install a manual transmission, the flywheel will be bolted on the block without the spacer. Be sure to add a pilot bushing/bearing at the end of the crank since the automatics did not require one!!! =)
The flywheel bolts to the end of the CRANK SHAFT with out the spacers. You must have been tired Prox...get some ZZZZ's
