mldub2 Posted May 17, 2010 Share Posted May 17, 2010 (edited) I am trying to put a 240z fuel tank in a 280z. Because when i bought the car it did not have a tank in it. My question is were does the outlets on the right side, back, and left forward go to and the the other forward ones that are close together are the fuel lines right? back forward Edited May 17, 2010 by mldub2 Quote Link to comment Share on other sites More sharing options...
silverarrow27 Posted May 20, 2010 Share Posted May 20, 2010 Yes the two small ones together are the fuel lines. All the other ones go to the vent tank or whatever it's called mounted in the trunk-passenger side. Quote Link to comment Share on other sites More sharing options...
mldub2 Posted May 22, 2010 Author Share Posted May 22, 2010 There is only 2 vent lines coming from the car and the tank has 3.Can i cap 1 off or what do i do. So it is okey to run the 240z tank on my 280z? Quote Link to comment Share on other sites More sharing options...
leroylucky Posted June 12, 2010 Share Posted June 12, 2010 (edited) Im wondering the same thing. Im doing a V8 swap in a 240 and just got a fuel tank. I dont need the return line so in gonna cap it, but what about the rest? Does anyone have any help for me? Edited June 12, 2010 by leroylucky Quote Link to comment Share on other sites More sharing options...
Tony D Posted June 13, 2010 Share Posted June 13, 2010 It wont go unless you have a 280Z with a full-sized spare---the space saver will have you making support brackets for the top of the tank as the 240 tank is significantly smaller in the spare tire area than the later (6-76 on) 280Z tanks. Midub has no location listed, but you two other guys in the IE and Los Angeles are in luck, I happen to have some late model 280Z tanks I might let go, PM me if you need one. They are baffled more than a 240 tank, and the pickup is a decent size (7/16" Hose 11 mm) compared to the 240 tank (5/16"-8mm). Return is same situation, 240 tank has a dinky 3/16" line (4mm), while the 280 tank has a 1/4" (6mm) line. Quote Link to comment Share on other sites More sharing options...
