rubber plugs
Ok I hope that I have this in the correct forum. I am in the process of removing the undercoating and painting under there. Its working well. I am using PB blaster to loosen the rubberized coating and then taking it down to bare metal with a wire wheel on a grinder. There are little holes in the frame rails and floor pans which have little rubber plugs in them. I tore one of these up with the wire wheel and I was wondering if anyone sells new ones? Thanks
These are just water drain plugs. I think welding them shut on the framerails would probably be a bad idea, you want water to drain from those holes, welding them shut could trap in moisture resulting in even faster spreading of the dreaded cancer
