1971 240z rb25det build thread
5thgenluder
While your changing the timing belt you might as well should change your water pump. I suggest you also change the thermostat for my thermostat was stuck closed due to the motor not being used for a long time. My Rb would over heat so quickly and i had to take the intake manifold out to service the thermostat. The gasket cost less than 2 dollars at autozone and the thermostat cost 9.99.
1994 300zx twin turbo thermostat 170 degree
1984 300zx n/a thermostat gasket
Edited by David GArcia
  On 10/6/2011 at 5:04 AM, 5thgenluder said:
Nm did some reading and I found out you can use black rtv. Mini update. Removed intake manifold, clutch, flywheel, oil filter housing, and wiring harness. Ordered new intake manifold gasket. Need a hoist to get the motor on the stand.
Make sure that is the RB25DET transmission, i cant really tell by the picture. There has been many cases where people got ripped off with the RB20 transmission when they bought an RB25 motor. Its way cheaper and weaker.
-Bohdan
-Bohdan
That's a rb25det trans I see in the pic.
Update: Dipstick relocation
Step 1. Remove the stock oil pan
Step 2. Remove brass plug shown here
from the other side
Step 3. Remove dipstick and swap for brass plug location. Used a punch and a flat head to pound it out. Havent fully pounded it back in. Waiting till I can make sure it lines up with the intake manifold.
Step 4. Punch brass plug into former diptick location.
More to come.
update: Oil pan
step 1 removed old oil pan. Scraped old gasket off. Did this with the motor right side up at 1st so the old gasket wouldnt fall in. Then flipped it over to make sure it was clean and mount the oil pan.
added oil filter
here is a few pics of the oil pan I got from Pat1
Used the silicon gasket maker that Pat provided for me. Mounted the pan tightening the bolts in the order the fsm lists and to the torque specs they list.
update: thermostat
Removed old thermostat.
Here it is off.
Installed new thermostat
Make sure the dot is at 12 Oclock
Mounted gasket and put it all back together.
Got the thermostat based off of David Garcias advice. Got them from autozone asking for these part #s
About $15.00 for both
Update: Timing belt.
Remove everything according to the fsm. The tricky part was getting the crank bolt off. What I did was install some of the flywheel bolts and put a breaker bar in it against the engine stand so it couldnt move. Then took a very large socket and cranked the bolt off.
Next up removing the crank pulley. Used a pulley puller that I rented from autozone.
Removed the upper and lower timing cover. Then pulled off the water pump.
Here it is off.
Scrapped off the old gasket. Installed new N1 water pump with gasket maker. Use the fsm to get the order to install the bolts and the torque specs.
New pump on.
Installed new tensioner pulley. Attatch spring like shown
Line up all the dots before mounting the belt.
Added the Greddy kevlar timing belt.
Another view from the top.
Then put it all back together.
Got some good info from here.
http://www.scribd.com/doc/16408415/How-to-GuideChanging-the-Timing-Belt-on-a-RB25DET
