_Donovan_ Posted September 1, 2010 Share Posted September 1, 2010 I have a 1976 280Z. I am installing a LT1 with the 4L60E transmission. The JTR manual shows a pic of the transmission tunnel and the bracket that needs cut out, then states that later models are different. Well, mine is different. What I am asking is for anyone that has a 1976 or one that is similar, how much do I need to cut out. Sorry I do not have a picture right now to show what I mean, I will try to get one later tomorrow. But a quick description will hopefully work. In the book it shows the brackets on the Z more or less look like triangles on each side. Seems pretty clear what to cut out, all of that. On mine, the bracket has a piece that comes across and also a sort of bracket I believe that goes all away up and around the tunnel. Hopefully someone knows what I mean here. I believe I need to cut it all out but I would like some confirmation first. Thank you in advance for any help. -Donovan Quote Link to comment Share on other sites More sharing options...
deja Posted September 1, 2010 Share Posted September 1, 2010 I had to cut out almost the entire mount that is welded to the car. This is especially true on the passenger side. Even then I still had to beat the tunnel a little to clear everything on the 4L60E. Quote Link to comment Share on other sites More sharing options...
GOTHALOSISM Posted September 1, 2010 Share Posted September 1, 2010 I'm going to cut out my mount today when I get home since I just got my tranny mount made last night. Mine is a 76 as well so if you can wait a day or so I should have some good pics for you. Quote Link to comment Share on other sites More sharing options...
_Donovan_ Posted September 2, 2010 Author Share Posted September 2, 2010 WOW, deja, you are a lifesaver. You answered my question exactly. Thank you so much. Friday I will be doing this. Glad to know what I need to do. Quote Link to comment Share on other sites More sharing options...
_Donovan_ Posted September 2, 2010 Author Share Posted September 2, 2010 Thank you also Gothalosism, looking forward to the pics. Quote Link to comment Share on other sites More sharing options...
GOTHALOSISM Posted September 2, 2010 Share Posted September 2, 2010 Oh forgot to say my tranny is a WC t-5 but I still need to cut out the mounts for clearance issues. Quote Link to comment Share on other sites More sharing options...
gvincent Posted September 9, 2010 Share Posted September 9, 2010 My Z is a 76 and I cut out the moiunts as shown in the pictures, I have a T56 and did not have to hammer anything, I did drill a 1" hole on the passenger side to clear the reverse light electrical connector, it rubbed and broke the top of the connector. So i replaced the connector drilled the hole and then covered it with a 1" rubber plug. Quote Link to comment Share on other sites More sharing options...
