Back to the jackstands .
Got the Z fired up yesterday to move it to the other end of the carport and some jackstands so I can fix it. It's been leaking oil, blowing oil and a bad noise in the back. Rinsed it off and went for a ride around town. Made it 1/2 block from the house, goosed it, big bang and rolled into the driveway.
Doing a r200/obx, poly bushing allaround, front brakes, SS brake lines, frame repair, 700r4 and rebuild the motor. I've Got alittle money, so hopefully have it running this year.
before pics.post-1382-081306300 1283540900_thumb.jpgpost-1382-032717600 1283540967_thumb.jpgpost-1382-071531700 1283541073_thumb.jpgpost-1382-064841700 1283541168_thumb.jpgpost-1382-081531700 1283541319_thumb.jpgpost-1382-052662300 1283541379_thumb.jpgpost-1382-033148600 1283541444_thumb.jpgpost-1382-026342400 1283541574_thumb.jpgpost-1382-013214500 1283541984_thumb.jpg
It’s always a mixed feeling to pull the machine back in the garage: disappointment that many years of work must be again followed by work, before driving can resume; but self-satisfaction that lingering ills can now be rectified.
I have to wonder, though… frame repair, replacement of all bushings, engine rebuild. It’s already September, and you’re planning on finishing all of this before the end of the calendar year? Now that’s dedication!
It's worse than that, Working out in gods garage and we've had snow in the hills already. I'm unemployed, I'm a masonry forman and there is nothing going on here. Ive had 3 years to think about it. Ive got time and some money. It's not unemployment.
The hood does have a hole. It doesn't stick over the cowl much so I was thinking I could put a piece of tin in the cowl to help. If I put a breather top on the air cleaner and seal it off, Ithink I'll get enough air. The guy that put he scoop on screwed it up and let it sag.post-1382-041909700 1283706485_thumb.jpgpost-1382-069455700 1283706542_thumb.jpgpost-1382-093139500 1283706586_thumb.jpgpost-1382-077140600 1283706631_thumb.jpgpost-1382-023466500 1283706764_thumb.jpgpost-1382-047988400 1283706813_thumb.jpg
The hood does have a hole. It doesn't stick over the cowl much so I was thinking I could put a piece of tin in the cowl to help. If I put a breather top on the air cleaner and seal it off, I think I'll get enough air. The guy that put he scoop on screwed it up and let it sag. It's cracking in acouple spots. Needs work.post-1382-041909700 1283706485_thumb.jpgpost-1382-069455700 1283706542_thumb.jpgpost-1382-093139500 1283706586_thumb.jpgpost-1382-077140600 1283706631_thumb.jpgpost-1382-023466500 1283706764_thumb.jpgpost-1382-047988400 1283706813_thumb.jpg
  • 5 weeks later...
